Question about Acer Aspire 1705SMi Notebook
Acer aspire 1705 smi charger problem
Hi,i have one of these laptops and the original charger stopped working,i bought a replacement from ebay which seems to work but when i connect it to my laptop nothing happens,no charging light appears on laptop and the power light on charger goes off as soon as i connect it to the laptop.does anyone have a wiring diagram of this model as i've been told it is something to do with the wiring of the 4 pin connector,cheers
  • Anonymous Nov 22, 2008
    I have just taken delivery of a new replacement AC adaptor. I have same problem. Plug it in - nothing. I note that if I unplug from the computer the green indicator light comes on. When mains is switched off the light stays on for some considerable time (unlike original). Implies a large condenser. ie electrically different from the original and not campatible with it.
  • 363 Answers
The power supply is detecting a fault. You are probably correct thinking it has the wrong pinout.
Before you pull it apart, consider returning it to the seller if it was sold with incorrect information.
If you disassemble anything, your refund/replacement and warrantee will be voided.
Posted on Nov 08, 2007
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
My cauzin Got Acer Aspire 5920 !! its charger stop working she buy another charger for it !! but due to inexperience she bought 24 volts instead of 18 volts !! after charging some time the laptop isn't...
One of two things. The Power Connector (on the motherboard) or the motherboard itself. If it is just the power connector, you can purchase a new one for around $10 (look at the specs for your model) and solder a new one on. If it is the motherboard, you'll be replacing alot more than it most likely. It could have fried the GPU, memory and Proc.
And the following three condition should be met for you to use an AC Adapter safely.
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19.5V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Specification of Acer Aspire 5920 Charger:
Output: DC19V 3.42A
DC Connecter (Barrel) size:
Internal Diameter: 1.5mm
External Diameter: 5.5mm
Feb 22, 2011 | Acer Computers & Internet
Acer aspire 5516 battery and charger problem
Hi, this could be an unhelpfull suggestion but the charger may not be compatable with your laptop. Laptops notoriosly have different power settings, you may be forced to purchase a new Acer charger. Try ebay, you may be lucky
Aug 01, 2010 | Acer Computers & Internet
Problems with new laptop battery for my Acer 6920G.
You can't force the battery with a higher charge to work without damaging the computer. If the battery is a direct replacement it should work. If your original charger is not capable of charging the battery you can consider a charger replacement but I suspect the original charger you where using was bad to begin with if that is the case. You can try locating a replacement charger but you need to make sure it is rated for computer so you don't damage the power system.
Jun 20, 2010 | Acer Aspire 6920 Notebook PC
Laptop will only charge when switched off
get orignal charger for acer aspire 5735 pc and then try again
May 03, 2010 | Acer Aspire 5735 Notebook
Acer aspire one notebook pc ZG5 model's adapter
Ebay is full of them, just watch the location and skip the ones made and shipped from Hong Kong, Good ones and one that will last do not cost 18 bucks, search for original Acer chargers and spend the extra funds.
Nov 25, 2009 | Acer Aspire One PC Notebook
I have an aspire 1711 SMI, who doesn't work properly since several months. The display was starting to fall down and now there's no diplay at all, completely black. Now, when I start the notebook, the...
Hi
This is a common problem. The problem is the inverter. I changed mine OK. Actually I changed the inverter once and the whole LCD screen twice! Now happy with working 1711.
two inverters here on ebay
http://cgi.ebay.com/ACER-Aspire-1700-1710-LCD-INVERTER-1702-1711-1712-1714_W0QQitemZ150404840875QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2304d3bdab
http://cgi.ebay.com/Acer-Aspire-1700-1710-lcd-inverter_W0QQitemZ150404836278QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2304d3abb6
search this massive thread and you will find instructions on fitting the inverter.
http://www.notebookforums.com/thread19756.html
Cheers
Oct 05, 2009 | Acer Aspire 1710 Notebook
Acer Aspire 1705SMi Notebook Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
