Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WFO2060 not spinning at spin cycle.
I have a Bosch WFO2060 not spinning at the spin cycle. It also won't do anything if put on a manual spin. The only thing that happens is the pump runs but the drum doesn't even try to move. Sadly I don't have a diagram so it's difficult to work out why the motor isn't getting power.
  • qwerty09876a Jul 02, 2009
    Thanks for some poor advice. Turns out it wasn't the massively expensive timer module you suggested but some relatively cheap bruashes.
  • 744 Answers
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Posted on Jul 01, 2009
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
Bosch washer won't spin with wet clothes
I am not sure if Bosch has a "load sensing" sensor, but I would start there else you may have a motor issue, or bad capacitor on your motor.
Aug 03, 2012 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
My washer will not spin, it sounds like it's trying to spin but it won't spin and if i turn the barrell by hand it spins so it's not frozen or anything. Any suggestions?
Hi mwilczewsk,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer makes a rattling sound when it starts the spin cycle. Sounds like gears stripping or something loose rattling around. Now it won't spin after the wash cycle. It will spin if I put it on the...
Sounds like you cannot activate youre imagination maybe Ill do this for you one time here goes ~: You or someone left coins in your pockets jeans cardigan whatever they got out of garment while in the wash spin and worked themselves into the machine and now its bug-gerred innit?
Jul 30, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Hi my washes agitators is working but it won't do anything else. It's not spinning or rinsing the clothes. the knob isn't moving from cycle to cycle. Even if I manually put it on spin cycle it...
Hello, Thank You for using FixYa. I will be helping you today.Check the lid switch. Since you didnt give a model number it makes it hard to figure out but sounds like the lid switch
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Roper Washing Machines
Bosch WFO2865GB that stops before the Spin cycle
probably not draining fast enough, check for blockages at filter, sump, outlet and plumbing
Mar 29, 2010 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
New machine, manual says run a spin cycle, can't figure it out
make sure you remove all the shipping bolts per installation instructions then rock washer with hand and screw legs down till it doesn't rock then load an go call me back if any problems
Dec 30, 2007 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Axxis WFL 2060 Front Load Washer Logo
466 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
