Question about Bulova Watch
Adjusting a slazenger stainless steel watch band
I have a man's slazenger stainless steel watch band and would like to know how to adjust the band to make it smaller?
escapement
  • 2334 Answers
SOURCE: purchased fossil ladies watch am4183
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Posted on Jan 02, 2009
escapement
  • 2334 Answers
SOURCE: I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
Do not forget to rate, please.
Posted on Jan 14, 2009
escapement
  • 2334 Answers
SOURCE: trying to shorten stainless steel watch strap
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 27, 2009
escapement
  • 2334 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Mar 19, 2009
  • 8 Answers
SOURCE: link removal from band
if you don't have the necessary tools or knowledge then your best bet is to take it in and have a professional remove the link(s) for you. It all depends but sometimes if you take it to Macy's or Neiman's they will do it for free.
Posted on May 23, 2009
How do I open the band?
How to adjust your watch band - YouTube
? 7:52
https://www.youtube.com/watch?v=Y37okQAN7uA
Jun 16, 2010 - Uploaded by WatchDudeMark
In this video I will show u how to size your watch band with around the ... didn't need to watch it as you're obviously too fxcking useless to do ...
How do I open the band? - Fixya
www.fixya.com/support/t26047908-open_band
33 mins ago - Generic Ladies TFX Stainless Steel Watch W/ Rectangle Face ...watch? The clasp won't open and I didn't want to pay $65 just for a new clasp.
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
Jan 10, 2016 | Generic Ladies TFX Stainless Steel Watch...
I have a ESQ E5262 stainless steel and the band is a little tight. I am looking for a band link.
go to a jeweler or watch maker as they often have spare links from bands they adjust in shop when making a sale
take the watch in to match the links
Nov 11, 2015 | ESQ Watches
How do I adjust the band on a Casio AQ 160 watch?
try this link below there are several diffarant band adjustments that may help you
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Nov 02, 2012 | Casio Watches
I have a tonino lamborghini watch and cant figure out how to set the time
The stainless steel band broke on my Tonino Lamborghini watch. Can anyone tell me how and where to get a new band? Or even a replacement link for mine?
Jan 07, 2011 | Bulova Watch
I need user manual/instructions for Slazenger, model not known
mcdevito75 here, You can visit a small watch repair shop in your area for info, as some watch makers only deal with their watches commercialy.
Jun 27, 2010 | Watches
I just bought a skagen stainless steel mesh band watch. I am trying to adjust the band to make it shorter. I have the piece the moves open, but I cannot figure out how to get it shut again.
http://www.skagen.com/service/watchInstructions.fx#adjustment
your watch has the skagen signature mesh band. its actually very easy to adjust once you figure it out all you need is a small screwdriver.
Dec 21, 2009 | Skagen Signature Mesh watch
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Extract the pins.
Take link(s) off.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
I need to adjust the belt of my new watch
How do you adjust a watch band (remove a link)
Mar 14, 2008 | Watches
Bulova Watch Logo
495 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
