Question about Washburn Wi14 Electric Guitar
I have a washburn WI 14 guitar and trying to change pickups. the old one is two wire. white and bare. the new one have like 5 wires. anyone replace the pickups in their wI 14?
  • ojisan_neo20 Jul 03, 2009
    Excellent. I got it. its sound great too. thanks
    Scholar:
  • 109 Answers
This is the way most aftermarket pickups are set up. Its to accommodate different wiring setups like coil splitting.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
Whether the pickup is a Duncan or not does not make a difference. Make sure you solder the red and white wires together(the ones together in the diagram) and cover the joint with heat shrink or electrical tape.
Posted on Jul 02, 2009
Could you please tell me the year of manufacture of Washburn mandolin serial number A16672.I suspect it would be approx 100 years old.
Here you go
  • Washburn Frequently Asked Questions - Washburn Guitars www.washburn.com/info/faq Washburn Frequently Asked Questions. General ... Can I buy an instrument from Washburn directly? Washburn Guitars are ... Washburn has used many serial number ...
  • SERIAL NUMBER - Washburn Guitars forums.washburn.com/index.php?topic=6344.0 The serial number will tell you a lot. Sammick guitar factory in Indonesia (SI). The first 1 or 2 numbers indicate the year of manufacture, so without knowing the ...
  • Vintage Washburn Mandolin Restoration: Serial Numbers ... www.vorreiterguitars.com/?attachment_id=1003 The headstock is stamped 10271 (across the grain) and 5280 (between tuner machines, along the grain).
  • Ventage Wahburn Bowlback Mandolin - serial number 17575 www.mandolincafe.com/forum/showthread.php?69653-Ventage-Wahburn...
    • 4 POSTS
    • FIRST POST: 2011-01-28
    2011-01-29 · Ventage Wahburn Bowlback Mandolin - serial number ... Wahburn Bowlback Mandolin - serial number 17575 ... book which includes serial numbers of Washburn mandolins...
  • Washburn Prewar Instrument Styles : Guitars, Mandolins ... books.google.com > Music > Musical Instruments > Guitar
    • 5/5
    • 2 REVIEWS
    This book is the first of its kind to report on Washburn ... rosewood ribs s/h bound serial numbers shaped tortoise ... Washburn Prewar Instrument Styles ...
  • How Can We Check Serial Numbers On Washburns? forums.washburn.com/index.php?topic=16011.0 How Can We Check Serial Numbers On Washburns? ... Washburn M4 mandolin Washburn M1SDL mandolin Epiphone AJ100VS Carlo Robelli J220-VS Guild Pilot Bass
  • Dating a Washburn Mandolin forums.washburn.com/index.php?topic=6573.0 I own a nice F type Washburn mandolin. ... Based on what I learned here about serial numbers, ... I have an old mandolin with Washburn sticker intact inside.
  • How old is this mandolin? - instrument resolved ' Ask ... ask.metafilter.com/244116/How-old-is-this-mandolin 2013-07-04 · From Washburn's website: Washburn has used many serial number formats over the years, ranging from 4-12 characters long. The year of manufacture ...
  • Washburn Mandolins www.washburn.com/products/bluegrass/mandolin Washburn has been building mandolins since the late 1800s so we know our craft and your mandolin is of the highest quality and finest tone. Whether you play bluegrass ...
  • May 25, 2016 | Music
    I have picked up a washburn lyon series electric guitar s/n 5062530 stamped on the neck plate what year is it and where is it made
    It's probably 1995 Washburn Lyon WE3, the pickup configuration is two single coil pickups. It would be easier to tell if there was a photo available.
    Dec 22, 2014 | Washburn Music
    I am replacing an input jack on Dean ML. However, the old one was not there and I need to know which wire is positive and which is negative. There is a clear coated wire and a silver white coated w
    With standard color coding of wiring, the clear coated should be the negative ground. However, this is not always a guaranteed bet. If you just want the pickup polarity, use a meter on ohms or continuity and test each wire to the pickup body, presuming the body is metal. The body should be ground. Otherwise try http://guitarelectronics.com/guitar-wiring-resources/
    or pininterest.com or ultimateguitar.com which have detailed wiring sketches of many pickups and associated wiring.
    Jan 17, 2018 | Dean Guitars Music
    Will volume and tone knobs for a Gibson fit on a Washburn HB30? Is the shaft and spline the same?
    Yes, Some gibson electric's have long shaft pot's, they will still fit but you will need to use another nut to adjust the pot's so they do not stick through the body to far. Knobs should fit unless the old gibson's are solid shaft. Then you will need new knobs. Many guitar parts places on net to order standard pots and even wiring kits. Try Allparts, , www.guitarelectronics.com/,, Guitar ******, then www.stewmac.com/
    Sep 11, 2011 | Washburn HB30 Semi Hollowbody Electric...
    Can i fit EMG 81 and 85 into my Washburn PS600 without much hassle or soldering? They currently have Egnator humbucker pickups installed as stock.
    EMGs have quick-connect wires now so that part shouldn't be much trouble. You will however have to carve out a cavity for a 9v battery and wire it to the pickups (you might be able to put it under the pickguard as well) . If you are worried about this I suggest you have it done professionally.
    Mar 09, 2011 | Washburn PS600 Paul Stanley Electric...
    Where could i find a chart where it shows how to wire an xb125 bass?
    Is this the Washburn XB125 bass guitar?
    Do you want to alter the controls, change pickups?
    Is there a problem with the active pickups? Too much output?
    What do you mean by "how to wire"?
    Have you gone to www.Washburn.com and asked at customer service?
    http://forums.washburn.com/topic.asp?TOPIC_ID=11660
    Dec 31, 2010 | Music
    Need wiring diagram for washburn lyon guitar
    Try this site:
    http://www.guitarelectronics.com/category/wiringresources/
    Find the schematic closely matching the resources of switches, pots, and pickups of your guitar.
    Jun 13, 2010 | Washburn X10 Electric Guitar
    I have a washburn rr 2v and when it is plugged into an amp there is no sound but all the wires are connected in the back and the pickups are still magnetic
    Here are some things to check:
    - Are all volume controls turned up 1/2-way? - Try a different guitar patch cable. - Does your amp have remote switchable inputs? Is your guitar plugged into the *active* channel on the amp? - Is the amp turned on?
    Feb 15, 2010 | Washburn X10 Electric Guitar
    Need to know what brand and size strings come standard on washburn wi-14
    I would recommend that you visit a local music store and ask which strings to purchase for your guitar. Or CLICK HERE to se some choices on the internet. Good Luck. I hope you make a hit record!
    Nov 09, 2009 | Washburn Wi14 Electric Guitar
    Washburn Wi14 Electric Guitar Logo
    762 people viewed this question
    Top Washburn Music Experts
    Michial Gueffroy
    Alex McGaughan
    Alex McGaughan
    Level 1 Expert
    rhodesworks
    Are you a Washburn Music Expert? Answer questions, earn points and help others
