Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
Printing to Canon Image Runner 2200
I added a print server to the parallel port of the copier, loaded the driver
iR2200_3300-PPD_1.81_Windows on the xp computer and added it as a local printer with ip address 192.168.1.215. tried to ping it and was successful. Tried to print a test page, it acted like it printed on the computer but when I went over to the 2200 is said receiving printing and data/process light flashed green...it never printed. I had to power off the print server and power it back on.
what should I do? Are there settings on the 2200 to change?
  • 4 more comments
  • marc526 Jul 01, 2009
    1. what is the problem will the 2200 print
    I tried to print a test page, I checked the ip settings as well, do you think there is a setting on the canon or it is a driver issue?
    where can i download the correct xp print driver for 2200?
    need more assistance with problem
    what driver do i download on the link there are alot to choose from? WIN XP.
    to be honest i do not know if the driver is correct on the computer, we are using a xp pro computer do you know what the correct driver would be and where to download it?
    Sniper:
  • 89 Answers
You installed a Network Multi-PDL Printer Kit C1 (N Boot Rom and NIC aka ethernet port)? This error you have is almost certainly a result of not upgrading the system software on the copier properly. The copier needs to have special firmware loaded to enable it to be used as a printer.
Go into Service Mode (Additional Functions [button has * on it] > 2 then 8 > Additional Functions). Go into Copier > Display > Version. If you have N BOOT ROM (required for printing) should have N at the end of number for BOOT-ROM. For printing need number for PS/PCL. I suspect you don't have a number for this.
You need SST, N system software for 2200 and either a nethawk cable (special canon usb to parallel cable and only one that works with Service Support Tool) or a computer (preferably running XP) with a parallel port and a IEEE1284 bi-directional parallel cable (kind of parallel cable that was commonly used with scanners, don't just try any parallel cable)
If you're not a tech you're going to need to get a tech to come and load the system software.
Posted on Jul 17, 2009
    President:
  • 942 Answers
Maybe the files installed are corrupted or some files missing, try to re-install the driver of your printer
Good luck!!
Regards
PCmania
Posted on Jul 01, 2009
  • 3 more comments
  • Neciforo Llanto Jul 01, 2009
    Give me the exact model of your printer, then i can download the driver
    Regards!!
    PCmania
  • Neciforo Llanto Jul 03, 2009
    The Windows XP is not the driver of your printer, did you remember the CD driver, it is package in your printer box , that CD in important you need to keep that CD. If that CD is lost, there are another option, you can download your printer driver,
    Give me the brand and model of your printer, i am the one who will give you the exact site,,,
    Good luck !!!
    Regards
    PCmania
  • Neciforo Llanto Jul 04, 2009
    To download your printer driver. go to the canon website, then search the model of your printer, after that you can see now the model of your printer, then download driver, after you download, install it in you computer, so that your printer will work properly
    Good luck !!!
    Regards
    PCmania
  • Neciforo Llanto Jul 06, 2009
    Hi..
    To download the driver you need to visit the canon site then search the model of your printer, the start to download the driver
    Regards
    PCmania
  • Neciforo Llanto Jul 07, 2009
    Hi,,,
    To download the drive you need to click the link below, then click accept to download
    http://www.usa.canon.com/opd/controller?...
    Regards
    PCmania
    President:
  • 1,383 Answers
Just refixc ink toner cartrdges then turn the on canon image runner again and check.
Alos check in control panel printer and faxes then right click on current prinrter and give test page.
Also check in adavanced that start priting immediately there.
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Printing on a Canon Image Runner 5000
go here and download the PCL5 driver for Windows XP (NOT THE 64 BIT version though):
http://www.canon.ca/english/index-softwaredownload.asp
The driver is the same regardless of the port. Just select "local" port when setting up.
Feb 13, 2009 | Canon imageRUNNER 5000 Copier
Canon Image Runner 2200 printer port appears to be disabled, How to you enable it from the printer console manager
You don't.
Go to Start|Printers| and then right click select your printer. Make sure there is an arrow next to the printer, and if not, select "Make Default Printer" in the properties drop down box.
Jan 22, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon ImageRunner 2200 printing
the parrellel port is used also to updated machine soft ware.... if you do not have the print bootrom installed it will not print sorry
Dec 22, 2008 | Canon imageRUNNER 2200
Help I can't get a Word doc to print on 11x17 on my canon Image runner 2200
guessing its the wrong print driver go to imagerunner ,com and look for different driver
Oct 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
219 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
