Question about Marantz SR-5200 Receiver
Only the main speakers are functioning....Hello, I m from India and I have a strange problem with my Marantz SR5200 which is sparingly used...It is perfectly working in the stereo mode whereas in others; only the front speakers are functioning while the other channels remain dead. In DTS and 6.1ch Surr mode the "PCM" indicator flashes and the signal is not locked and so I don't hear any output. I tried the test tones and it behaves similar only the front left and front right are responding while the rest are dead....All this happens when I connect through the digital inputs.... Now, when I use the analog input there is no output until I switch to source direct mode. Now, when I apply the 7ch Input I get to hear from all the speakers.... Please suggest a remedy for this problem.... I'll be very grateful if someone could provide me with a user manual as I have misplaced my copy of it... Thank you, Ajay.
Re: Only the main speakers are functioning....Hello, I m...
Replace the A/D converter CS4228A on the DSP Board
Posted on Nov 24, 2007
0 characters
3 Points
Connecting Speakers to Marantz NR1402
You can use banana plugs to connect speakers to the speaker post. Connect the wire to the banana plug then insert the banana plug in the speaker post.
If you serch in google with the name speaker banana plug then you will get picture of different types.
You can buy this banana plugs in any nearby electronic spare part shop. They all stock this item. Normally comes in pair ( red, black)
Feb 22, 2012 | Marantz Audio & Video Receivers
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Mar 19, 2010 | Marantz SR-5200 Receiver
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Oct 17, 2009 | Marantz SR8001
Receiver Sr5200 shut down in 5.1 mode
chances are you have the volume too loud and the speaker wires are crossed.
all speaker wires need to be with the positive on the right and negative on the left if you have them anywhichway than it will work on low volume and not a very good sound.
look closely at the wires and they should have a red or so color on one side or the wire jacket itself will have a round side and a flat side
Apr 21, 2009 | Marantz SR-5200 Receiver
No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
Feb 21, 2009 | Marantz SR-5200 Receiver
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Feb 11, 2009 | Marantz SR-5200 Receiver
SR-5200 owners manual
Jun 26, 2008 | Marantz SR-5200 Receiver
I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Feb 05, 2008 | Marantz SR-5200 Receiver
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Aug 26, 2006 | Marantz SR-5200 Receiver
Marantz SR-5200 Receiver Logo
373 people viewed this question
Top Marantz Audio & Video Receivers Experts
Pieter Vleeshouwers
Are you a Marantz Audio and Video Receiver Expert? Answer questions, earn points and help others
