Question about HP Hewlett Packard Officejet 7310 InkJet Printer
My printer is not responding to my computer.
I have used this printer for a few years with no problem. I tried to print a document 7 times and nothing happened. There is an Icon that shows asking me to delete my hardware (hp officejet 7300. I dont know what that mean so I go into PRINTERS AND FAXES. This actually shows the 7 documents that needs printing but for some reason the computer wont allow me to refresh or delete. I recently installed AVG security software. Maybe that has something to do with it but im not sure. I simply dont know what to do next. Need Help. All plug ins have been checked.
  • Tonya Wilson Jun 04, 2013
    I have recently chosen avast security but when I try to print it tells me I my computer cant print and this was a day after receiving Avast Security. I need my computer to be compatable with my printer please help
    President:
  • 3,278 Answers
Go back into Printers and Faxes, delete your printer icon, restart your PC and reinstall your printer driver. Good luck.
Posted on Jul 01, 2009
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
Lexmark X1250 suddenly won't print
ok..turn off the printer..and unplug from computer..let it sit for five minutes..
Oct 28, 2008 | Office Equipment & Supplies
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
I have a Lexmark x7350 connected to a PC running Win7. I have previously been able to print with this combo with no problems at all. I have removed the device, uninstalled the Lexmark software, rebooted,...
Please follow the steps on to properly Uninstall Lexmark Printers from your computer. After the uninstallation process is done, reboot pc when prompted.
When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the link below to download and install the Lexmark X7350 Printer Driver on your computer. Note: Use the Vista Driver on Windows 7. - Lexmark X7350 Driver for Vista 32-bit - Lexmark X7350 Driver for Vista 64-bit
When the installation process is successful, try to print a document to verify that the problem is fixed.
Sep 11, 2011 | Lexmark X7350 All-In-One InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Hi please help? My HP all in one deskjet f380 only prints certain documents, It starts as if its going to print, moving back and forth and then just stops and nothing is printed. The print job dissapears...
Try if one of these solutions help you.
1. Shut down you printer, wait a few seconds, start it again and try to see if you document is printing.
2. Install the printer again on your computer. This time, if possible use an other USB port.
3. If you can print PDF, you can try http://www.freepdfconvert.com/ and print your document after you mad a PDF.
Jul 07, 2011 | Office Equipment & Supplies
Computer shows document as printing, does'nt print out
check if there is a pending documents to print, or cancel your current documents then restart of switch of your printer in 1 minute then switch on again then try to print again..
Mar 02, 2011 | Kodak ESP 5 Printer
I just bought a whole set of inkjet cartridges. My printer went through the cleaning process. Then it started printing a document. But there was nothing printed on the paper. The paper was clean without...
Please try to to print a test page and see the results. If the test page prints correctly then there is nothing wrong with your printer. Since you have changed the operating system you are required to update the printer driver. For that go to your printer site. Under the support find out which driver is compatible with windows 7. Download the same. You should not have any difficulty printing when you have the latest driver.
Feb 18, 2011 | Brother MFC 240C All-In-One InkJet Printer
Orange light blinks 7 times then green light once and repeats,
It indicate that your print head may defective probably cause by electrical connection, u can try to unplug the print head and clean the electrical contact part with dry paper and install it back. Make sure the contact part is fix into the holder completely.
YBC (/\)
Oct 07, 2008 | Canon i950 InkJet Photo Printer
HP Hewlett Packard Officejet 7310 InkJet Printer Logo
1,114 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
