SOURCE: check gngine light
Ok I think you meant code P0171, this means the fuel trim is always lean, you need to check for a engine vacum leak, maybe a cut or damaged PCV hose or any other hose that is in the vaccum system, I have read other Kia owners (Kia Forums, you should join one) reports of this same code, most found it not to be the O2 sensor but a vacuum leak.
SOURCE: 2005 Kia Sportage serpentine belt
YOU NEED THE BELT TENSIONER TOOL ITS FITS IN THE SQUARE SLOTS IN THE TENSIONER.YOU ROTATE TENSIONER CLOCKWISE TO REMOVE BELT.
SOURCE: 2002 kia sportage with P0171 diag code. Fuel
you have a vacum leak either in a hose or a vacum cap, check all hoses and caps, replace questionable peices
SOURCE: how to remove oil pan on kia sportage 99?
Hi Zak:
Kia Sportage 1998-02 Repair Guide
Oil Pan - Removal & Installation
Negative battery cable
2 Top intake manifold bracket bolts
Front 3 axle housing mounting bolts, 4WD only
Left front bushing from the axle housing mount and lower the front axle housing
Both gusset plates from the engine
Transmission under cover
Engine under cover
Oil pan mounting bolts and using a scrapper tool separate the oil pan
Oil pan
Oil strainer assembly
Oil baffle
Fig. Exploded view of the oil pan assembly mounting
To install:
Fig. Tighten the oil pan bolts in sequence
Oil baffle. Torque the bolt to 84 inch lbs. (9.5 Nm).
Oil strainer. Torque the bolts to 84 inch lbs. (9.5 Nm).
Oil pan. Torque the bolts to 84 inch lbs. (9.5 Nm).
Transmission under cover. Torque the bolts to 84 inch lbs. (9.5 Nm).
Gusset plates to the engine. Torque the bolts to 33 ft. lbs. (45 Nm).
Engine under cover
Front axle housing into position. When properly aligned, torque the bolts to 48 ft. lbs. (65 Nm).
Intake manifold bracket bolts. Torque the bolts to 34 ft. lbs. (65 Nm).
Hope helps with this (remember rated this) Good luck.
SOURCE: how to change plugs on 02 kia sportage
Keep a regular schedule for inspecting the spark plugs on your 2002 Kia Sportage. According to the official 2002 Kia Sportage owner's manual, spark plugs and ignition wires should be inspected every two years or 48,000 miles, whichever comes first. Let your 2002 Kia Sportage sit for a few hours before opening the engine compartment. You want to make sure that the engine is cool before you begin working on it. Pop open the hood of your Sportage and locate the ignition wires, which will be attached to the top of your engine. The 2002 Kia Sportage has a four-cylinder engine, meaning there are four spark plugs each attached to an ignition wire. The ignition wires run from the engine to the fuse box, which is located in the left side of the engine compartment. Inspect the ignition wires of your 2002 Kia Sportage. These wires will need to be replaced if they appear worn. Disconnect the ignition wire to your spark plugs. Grab the rubber boot located near the base of the wire and pull upward instead of yanking on the wire. Remove only one wire at a time, or mark the wires with a colored Sharpie marker before disconnecting all of them. Improperly reconnecting the ignition wires can seriously affect the performance of your Kia Sportage. Attach the spark plug socket to your socket wrench. Use the socket wrench to remove the spark plug from the top of the engine's cylinder. Inspect the spark plug. There will be some soot, but if the spark plug is completely covered in soot, it needs to be replaced. Position your replacement spark plug in place and secure it with the spark plug socket on your socket wrench. Be careful not to overtighten the spark plug after it has been snuggly fitted. Position the rubber boot of the proper ignition wire in place above the spark plug and insert it with your hands. Close the hood of your 2002 Kia Sportage
ENGINE OIL ISSUES/ OIL LEAK
The
oil is getting leaked from its running area. The oil pump has to be pressure
tested by pressure test to confirm the leak and area of leak: -----
For
step by step troubleshooting check the help links mentioned below: -----
Click
the link below: -----
http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
http://whatisbyme.blogspot.in/2012/06/high-oil-level-on-dipstick.html
Kia Sportage
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
http://whatisbyme.blogspot.in/2012/06/overfilling-oil-in-engine.html
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
http://whoisbyme.blogspot.in/2012/07/how-to-reset-oil-change-indicator.html
These
details will help.
Thanks.
The
For
Click
Kia Sportage
These
details will help.
Thanks.
How to
For your help, there are few Car Engine oil related solved problem
listed below. You can go through it.
High Oil Level on Dipstick
Oil light came on and the car died?
http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html
How to replace Oil filler cap or breather cap?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html
Oil pouring out from left front of engine?
http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html
Common Causes of Car Oil Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
2004 Dodge Stratus: Windage Tray Problem
http://howtobyme.blogspot.in/2012/07/2004-dodge-stratus-windage-tray-problem.html
Toyota Highlander Sport Oil change details?
http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html
Low
oil pressure light on Dodge Magnum?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
Kia Sportage leaking oil from oil pan?
Car Turns OFF
due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
Toyota Corolla leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Overfilling oil in engine?
2000 Dodge Ram 3500 Cummins Diesel: Oil Leak
issues?
http://schematicsdiagram.blogspot.in/2012/06/2000-dodge-ram-3500-cummins-diesel-oil.html-----------
These will help.Thanks.
