Question about HP Photosmart C6280 Printer
A sheet of paper has gotten jammed in the printer and I can't reach it to pull it out.
  • 1 more comment
  • cstclair2 Jul 01, 2009
    I can't pull out the cartridge bank
    I can't get the printer bank out and the paper is jammed deep inside
    Beautiful! clear, concise, I learned something about the printer that I didn't know before. THANK YOU!!!!!!
    Sniper:
  • 111 Answers
Don't pull it out that will damage ur printer spring. Simply try to remove cover of ur printer or try to push paper inward.,
Simply open up the back end of the printer (Not where you insert the ink cartridge).
There should be some kind of a switch of lever
Regards Mohit
plz vote
Posted on Jul 01, 2009
    President:
  • 1,383 Answers
First open the front door then pull out thew ibnk cartr5dge then pull the paper if you find.
Then check in back side of printer if you find any paper jam in back isde thenn pull the jammed paper.
HOW TO REMOVE BLOCK PAPER
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Oct 26, 2010 | HP LaserJet 1320 Printer
WILL NOT PICK PAPER SAYS PAPER JAM
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
Aug 17, 2010 | Dell 924 All-in-One InkJet Printer
The paper is jammed. How do i get it out?
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jun 27, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Our Deskjet D4160 had a jam and the paper was pulled out. the paper feed button is blinking and does nothing when we push it. We have restarted the computer, unplugged the printer. What can we do to get it...
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jul 07, 2010 | HP Deskjet D4160 InkJet Photo Printer
How do i clear a paper jam
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
May 04, 2010 | Dell Photo 964 All-In-One InkJet Printer
Where is Jam 2 located
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 26, 2010 | Brother HL 7050 Laser Printer
It wont print
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 22, 2010 | Brother HL-2040 Laser Printer
When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
just folowe the steps
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 21, 2010 | Epson Aculaser C1100 Printer
Paper jam in fax how do I clear?
folow the instruction
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
    False paper jam
    If the paper is lodged too far into the printer and can't be removed:
    Press the power button to turn the printer off.
    Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    Close the front cover.
    Press the power button to turn the printer back on.
    Resend your document to print.
    Ensure that:
    The paper is a recommended paper for inkjet printers.
    You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    The printer is on a flat, level surface.
    The left paper guide is against the side of the paper.
    You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    The left paper guide does not cause the paper to bend in the sheet feeder.
    Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    Envelopes or the appropriate specialty papers are selected in the printer driver.
    You are using a paper or envelope size supported by your printer.
    Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
    HP Photosmart C6280 Printer Logo
    mukhtar21 shaikh
    mukhtar21 shaikh
