Question about Microwave Ovens
Frigidaire microwave won t turn off
We hava a 10yr old frigidaire microwave that runs when the door is closed. In other words, the fan and light run when you close the door, even though there is no cook time programmed. Also, you can try and program cook times, but they will not run Any ideas?
  • 1 more comment
  • Fownser Nov 08, 2007
    How confident are you about the solution to this problem? Just wanted to look at every angle before we spend several hundred collars on a new unit. If you are sure about the recomendation....any thoughts on what brand microwave to consider that will last and have a favorable price point? Thanks...
  • Anonymous Mar 17, 2014
    Frigidaire.microwave hums when the doors closed
  • Anonymous Mar 30, 2014
    When I have finished cooking after closing door my microwave still runs
  • 4,102 Answers
This is a problem with your programme timer these can be expensive to replace and because of the age you will probably be better buying a complete new unit as you could repair it and you could come across other related problems and could end up spending a fortune sorry i couldnt be any more help
Posted on Nov 08, 2007
  • paul proctor Nov 08, 2007
    as i am not in us i wouldnt be able to advise on what is the best one as we have different brands plus you probably get the news ones out before we do but from experiance ive found sanyo and panasonic are good units and tend to last a bit longer than others you could price a timer but you will probably find as i did that it is cheaper to buy new one sorry couldnt be anymore help and morphy richards do some stylish ones if you are after stainless steel ones try a morphy richards as these tend to last for ages and usually have staniless steel touch controll witch are more protected than the older ones the timers stand up to higher demands of use hope this is some help.......................................................
Fan and light come on when door closed!
Door ailment may be a issue or the brackets that hold the switches maybe old and moving. Or wrong switch in wrong spot..
Nov 10, 2015 | General Electric PVM1870 Microwave Oven
Frigidaire gallery microwave light stays on and internal fan stays on
Good Afternoon Friend, thank you for your post!
I see that the internal light and fan continues to run on your Electrolux microwave with the door close. This sounds like the issue is related to a faulty door switch. I am fairly confident that an authorized service agent will be able to restore your microwave to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. Hope this helps! - Z
May 20, 2014 | Microwave Ovens
We can put in the minutes and temp., then when we close the door the clock times down and the fan blows, but nothing cooks. Fridgidaire model cfmv156fmc. For a while if we put a piece of cardboard in by...
I threw mine away because frigidaire would not do anything for it and was less than 6 months old . local dealer would not look at it as we bought from a big box store not them .
Dec 09, 2017 | Frigidaire Microwave Microwave Oven
Firgidaire Microwave fan runs when door is closed. Model FMV157GS
I'd bet the fan and / or turntable also run when the door is closed, which means you have a shorted relay on the control board, which can be repaired for $39.95 in most cases. Details are here.
Apr 28, 2011 | Frigidaire Microwave Ovens
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
All the lights and buttons on the front of my Frigidaire PLMBZ209GC work but the turn table does not turn and the fan does not run and it does not heat. It counts down and the cook light beside the timer...
Hello :
That problem could happen because of a bad door switch .
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
That could happen because of slamming the door and not closing it gently .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 31, 2010 | Frigidaire Built-In Microwave
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave Ovens Logo
704 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
