Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
How do i install the spring throttle on a lawnboy 10323
  • 89 Answers
Take the air filter off the spring is attached to the govenor rod to a fixed arm once attached the arm can be bent to tighten the spring or bent the other way slow the speed tighter the spring faster the speed there is another rod attached to the govenor rod to the throttle
Posted on Nov 05, 2009
  • dylan-ellis1 Jun 27, 2011
    is this for the choke cable or throttle ?
I need to download an owners manual 10323 lawnboy mower
Hi Nancy,
here is a link to a page that should help. It looks like you may have to purchase the download:
https://lookup3.toro.com/request/sendreq.cfm
Good Luck!
Jim
May 25, 2016 | Garden
Lawnboy Commercial Mower - idle speed adjustment
did you have the governor arm off of the motor
Jun 06, 2013 | Garden
I have a lawnboy self propeled mower model #10533. the serial number is 6907889. i do not know where the spring-choke return spring goes. if i had a picture of it installed i could do it becuase i am not...
For getting big view of picture please click on the link below http://www.ask.com/bar?q=lawnboy+self+propelled+mower+model+%2310533&page=1&qsrc=19&dm=all&ab=5&u=http://www.partsandservice.com/html/Lawnboy/Lawnmower/10533.html&sg=jTUCMw17SUPaA/y4FH3G/QzzCbOKvHGnvkxGP%2Bp36m4%3D&tsp=1276102809824 Part number 5 is what you want to see in the fig and fit. 1 1 Housing, Deck (Incl. Ref. #2 & 40)
2 1 Decal, Danger
3 1 Decal, Deck
4 1 Shield, Trailing
5 1 Spring, Extension
7 2 Screw, Hex Hd.
8 1 Ramp, Discharge
9 2 Screw, Shoulder
10 2 Clamp, Hinge
11 2 Bolt, Wheel
12 2 Knob, Arm
13 2 Washer, Flat
14 1 Seal, Door
15 2 Screw, Thread Form.
16 1 Brace, Door
17 2 Pin, Hinge
18 4 Nut, Lock
19 1 Decal, Warning
20 1 Door, Discharge
21 1 Panel, Vertical
22 2 Spring Arm ***'y, Front
23 2 Bushing, Door
24 1 Cover, Access
25 2 Hanger, Shield
26 1 Cable, Door
27 1 Handle, Hood
28 2 Screw, Tapping
29 3 Screw, Tapping
30 2 Seal, Door Side
31 1 Seal, Door End
32 2 Tire & Wheel Assembly, 8"
33 4 Washer
34 2 Arm, Pivot
35 1 Bracket, Discharge Ramp
37 1 Panel, Screen
38 1 Screw, Thread Form.
39 2 Bolt, Shoulder
40 1 Decal, Warning
41 1 Decal, Instructions
42 2 Cap, Hub
43 1 Decal, AppliqueThis are the parts in your mower.Thanks. keep updated for any morequery.you can rate this solution and show your appreciation.
Jun 09, 2010 | Garden
There does not seem to be a spark. I even put fuel
is the deadmans handle pulling the cable enough to cancel the off switch? if not relase the cable from the handle, TIE A KNOT IN IT(!), re fit to handle, & bingo!
If the cable is working well enough already DONT tie a knot, it wont help, its the ignition coil! ( around £30)
Apr 02, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Oct 22, 2009 | Garden
Rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Sep 28, 2009 | Garden
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 | Garden
Lawn boy mowers
check for stuck float in the float case youll find a small needle valve which is adjusted.. by the level of fuel when it raise the float the float lifts the neddle up to allow fuel to pass to the intake it may stuck..or check your governer on top of your fly wheel.. if your have a standered carburator with a pump,, that bolts to the side..similer to breggs and straton... their a spring and a short thin rod that opreates the govener..if the spring is streched or the thin rod is bent out it will cause the mower to run high speed....heres a idea,, you know a carbarator. makes a engin run fast or slow..it has to have something to adjust the speed on it..start their first..
Sep 29, 2008 | Garden
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,749 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
