Question about Icon Image 17.5 S Treadmill
Replacement Motor GS Electric 2.5 HP 7000RPM 21 Amps Icon part number 124184 120 V B4CPM-078T
  • santafe2 May 11, 2010
    Try the TreadmillDoctor. com they have a lot of things like that.
Can you email photos of the motor? I may be able to help.
Posted on Jul 15, 2009
I'm installing a 8NE-L , 1HP pump . How far can I run my 12/2 wire for 110 volt application?
The FLA (Full Load Amps) for a 1 HP single phase motor is 16 amps at 115 volts. 5% is the maximum allowable volt drop from the main electric panel to the pump per NEC (National Electric Code). When these values are plugged into the volt drop formula, such as this one:
http://www.nooutage.com/vdrop.htm
90 feet is the maximum allowable distance for a #12 copper rated at 75 degrees C.
May 03, 2011 | Sta Rite 1 Hp Above Ground Pump Ne641
I'm looking for a replacement impeller for a 1 1/2 hp centrifugal pump (for irrigation) and the only info I have for the pump a partial plate on the electric motor. This pump probably is about twenty years...
Hi, If you have removed the old impeller, the part number will be in the center. If wear has obliterated the part number, then the replacement impeller will be either spx1610-c for medium head or spx1611-c for a high head. Later models of super pumps will have a 2600 series of numbers for the upgraded drive train. However, the 1600 series drive train parts are still available.
Nov 22, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
What size compressor can I run
You would need 10 times the watts it takes to run electric air compressor,the start up takes a lot more amps to get it going ,then it will level off to the amps,what ever they are.That is the problem,getting it to power up,then it is fine,so you are looking at about 8000 watt gen.
Jun 13, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
I have an old Black and Decker 18 electric mower that has reached it end of life. I don't have a model number, it has two 9 or 10 inch blades with belts back to the motor. It is an old orange version. I...
Here is the black and decker website:
http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1498.1670
Most the old models where 6 amps. 1/2 hp
You can get another one from ebay or craigslist
Sep 04, 2009 | Black & Decker 18", 6.5a Electric Mower
NSR250 MC21 92 Not hitting power band, fine until around 7000rpm
not familiar with your bike but some bikes have electric controlled power band an some have mechanical.Electric ones usually do a quick self diagnostic on start up hope that helps
May 22, 2009 | 1992 Honda NSR 250 MC 21
Change from 220v to 110v on air compressor
I can't blame you for askig, but here's my response. 5 HP is 3750 running watts. or about 35 amps at 110 volts and it would take somewhere around 50 amps to start it provided the motor could even be wired for 110 which I don't believe it can and for that exact reason. I'm sorry, but it's just not practical.
May 16, 2009 | Coleman Air Tools & Compressors
Rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Icon Image 17.5 S Treadmill Logo
260 people viewed this question
Top Icon Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
