ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
Was this helpful?
Yes
No
Popular Solutions for Hotpoint HSS25GFP Side by Side
the plastic part holding the glass shelves in place have broken. one by one they broke, shelves...
(More)
the plastic part holding the glass shelves in place have broken. one by one they broke, shelves would fall off of the brackets. also the plastic bracket holding one of the drawers in place has broken..not made well at all
Just returned home from Thanksgiving and refrigerator is not working and there is a clicking noise...
(More)
Just returned home from Thanksgiving and refrigerator is not working and there is a clicking noise at the back of the unit...a methodical clicking noise every second...I have read that it could be the relay. Is the relay on the motherboard and if so which one of those blocks is it?? Also I took the lowest back panel off and the thing that the fan is attached too is covered in lint/dust...need i clean it, does that help?? Thx. Also, where is the best place to get relays and motherboards if necessary?
Model HSS25GFPHWW does not work, freezer or frig. Replaced main circuit board nothing changed. Light...
(More)
Model HSS25GFPHWW does not work, freezer or frig. Replaced main circuit board nothing changed. Light buzz sound off and on and light on freezer door flashes.
side by side ice and water in door making growling noise at ice maker had to replace water line...
(More)
side by side ice and water in door making growling noise at ice maker had to replace water line water was off but icemaker was not when i turned water back on after about 1 hour it started making intermittant growling noise
