SOURCE: Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray.
Cause:
Extended tray is not set up properly for envelopes.
Solution:
Fixed! Did not fix.
Enter tools "Login" 1,1,1,1,1
Touch buttons with the following names in that order:
System Settings
System Settings
Common Settings
Other Settings
Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking"
Close out tools.
SOURCE: printer indicates paper jam every few pages, but
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
SOURCE: xerox workcentre pro 90 says
Take the paper tray out as follows: open the front door, pull the tray out as far as it goes. On the side rails there is a hole and if you look into the hole there is a stopper. Turn this stopper a little by a small screw driver or similar and simultaneously pull the tray out on the other side, then the remaining side one by one.
On the back side of the tray there is a sector plastic gear and a smaller one. Sometimes they lose teeth because paperr stack is very heavy and thy are made of plastic.
Another cause may be improperly installed feed rollers.They must be installed right way round. When paper stack raises the feed rollers actuate a fork which, in turn, actuates a plastic flag which in turn blocks a sensor in the inside back wall if the copier/printer. Everything is fu**ing plastic and breaks easily.
SOURCE: Xerox WorkCentre Pro 123 would like to make a copy
Just go into user mode and select the tray with the 11 x 8.5 as the default tray.
