Question about Cobra Microtalk 100 FRS Walkie Talkie Radios 2 Pack
What channel do I put the radios on to charge it or how do I charge it? The radios don't seem to charge.
    Problem Solver:
  • 14 Answers
Turn the radios off when you are charging them. The charger may not have the current flow to effectively charge the radios when they are on. If you need to monitor a channel, try charging them one at a time.
Regards,
Longshorts.
Posted on Jul 24, 2009
The radios charge up good and everything seems to work fine, except I can't change the channel. The channel buttons on both radios are not working on both radios which seems very weird.
They must be locked. To unlock, usually you press and hold a button with a "key" symbol. Model and brand would help a lot to "unlock" the mystery.
If you like this answer, please rate it.
Nov 05, 2015 | Radio Communications
Can't get motorola talkabout em1000 series kem-pk14190-67 to work
If you have a pair of them, just set them both to the same "channel" and "Code". If you have two different models, even if they're both Motorola, they may not use the same index numbers for the same settings.
Mar 19, 2013 | Radio Communications
Audiovox FR-530 two-way radios don't communicate
Re-programming of all your radio to synchronize its default frequency,will solve your problem,
Thank you my friend
Jan 28, 2013 | Radio Communications
Motorola Talkabout T5700 Two Way radio one not working
The battery may be dead. If it was indicating it was charging for 48 hours and still did not work, you can be pretty sure it will not charge again.
Oct 02, 2012 | Motorola Talkabout T5700 AA (22 Channels)...
How to program a pro - 135200 channel hand held scanner with out charging me .
  1. 1. Press "MAN."
  2. 2. Press "ENT/PGM" to put the scanner in programming mode. You will see PGM appears.
  3. 3. Use the number keys to enter both the channel storage bank and the channel number you want to assign to a frequency.
  4. 4. Press "MAN."
  5. 5. Use the number keys to enter the frequency and don't forget decimal point.
  6. 6. Press "ENT/PGM" to store the frequency into the channel.
  7. 7. you just stored a frequency into a channel. Repeat steps above until you have your scanner programmed how you want.
  • Hope this helps...
Nov 26, 2011 | Radio Communications
My car stereo seems to lose signal on all the radio stations. The preset channels are all there, but no matter which channel you put it on, it plays for a couple of secounds and then comes up with...
Sorry, but solving this requires a tech to see it in person. Assuming that your antenna is not broken, the first thing I would ask you is if you had anything done to the car recently. If you haven't done anything, I would pull out the radio and make sure the antenna cable is plugged in tight. Other than that it can be electrical. See if your radio works with the engine off, or maybe with the engine on but only in park. Find a local stereo installation service and see if their willing to take a look. Usually we don't charge to take a look. I never did. Good luck. =)
Aug 18, 2011 | Car Audio & Video
I want to know the correct method on how to do a SWR test with the Galaxy 959.I have a 5 foot self adjustable firestik and have mounted it to a 4mm thick aluminum plate 30 cm square and will have it higher...
The best way is with an antenna analyzer but that is too expensive unless you do SWRs for a living. The meter on the radio should suffice for your needs.
Adjust the screw on the antenna until it is about 1/2 inch out.
Place the srf/swr switch to swr.
Go to channel 1 and note the SWR reading on the meter.
Go to channel 40 and do the same.
If channel 1 SWR is higher than channel 40, then screw the tuning screw out a turn or 2.
If channel 40 SWR is higher than channel 1, then screw the tuning screw in a turn or 2.
Repeat until the SWR on channel 1 is the same as 40. Channel 19 will be the lowest.
If you are not comfortable using the built in SWR meter, you will have to invest around $20 for a small SWR meter.
,,,,Don at NTCB, Inc.
Jun 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
I can't get either radio to transmit or receive
try this get someone with a radio or scanner and see if you can be heard on there radioor try this put the radio in simplex mod and turn off the tone
Jun 26, 2009 | Motorola T5920 (7 Channels) 2-Way Radio
Batteries not charging
Michael
Are the batteries the original power pack? this charger are disigned for work just for this batery packs only.
Check if the conctas on the battery lead for dust or corrotion.
Oct 08, 2007 | Motorola Talkabout T5700 AA (22 Channels)...
Radio Communications Logo
366 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
