Question about Black & Decker DeWalt DW9055 5-3/8" x 16 Tooth Carbide Circular Saw Blade
B &D saw 5150 is shotting blue sparks. What is the fix?
    President:
  • 1,723 Answers
Check the brushes, clean the commutator with fine sand paper.
Posted on Jul 01, 2009
Accidentally ripped powercord into half and it is discontinued all over internet.What are my options to fix it myself?
I would find an extension cord of similar diameter. Cut the "female" end off, and open your saw up. Connect the cut end of the new cord to the same colors ...
This should not be difficult.
Oct 15, 2015 | Skilsaw 5150 Circular Saws
Loaned a Skil 5150 to a friend and when he returned it, the saw seems to run slow and the brushes produce lots of spark.
You will need to change the brushes for sure.Easy job at least.There are two types of brushes,The ones that can be fixed without taking the saw apart.The other brushes once you open the case and look at the front of the brush holders you will see some small holes.Take out the old brushes and push the new brush past the holes and push a piece of wire through the holes.Make sure the wire is long enough to go through a vent so you can pull it out when every thing on the body is buttoned up.
I use a piece of cardboard or Styrofoam to keep track of the bolts by just poking them in as I take them out,a magnet is good for the small stuff.
May 28, 2011 | Skil 7 - 1/4" Electric Circular Saw...
Runs rough makes noise and blue sparks come out motor.
the motor armature is welded at the commutator and is shot,it is cheaper to buy a replacement motor than have the armature repaired
Apr 12, 2011 | Dewalt DW744 Factory Reconditioned Heavy...
How to remove the blade from a Skilsaw #5150
Should be a locking mechanism on back of saw push or pull the hold blade still...then use adjustable wrench to loosen nut on saw blade..pull off blade..slap a new one on..and away you go!!
Jun 07, 2010 | Skil Saws
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
No spark at plug. so iam guessing coil is shot. mac 110
Hi
You will have to remove the engine from the houseing to get to the coil.Not a easy job. It does not have points
Sam
Jan 07, 2010 | Poulan Pro Chain Saw 46cc 20"
My stove up was about to blow up!! saw some blue lights flickering inside the stove!! please help
Find the 50 amp breaker and turn it off or pull out the bottom drawer and yank the cord out. Your bake element is probably shot. Arc welding itself to oblivion. Easy repair.
Oct 27, 2009 | Kitchen Ranges
Black & Decker DeWalt DW9055 5-3/8" x 16 Tooth Carbide Circular Saw Blade Logo
135 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
