Question about Silver Jeans NuVinci Gearless Drive Hub 36H Silver
Play in the hub
Hi
I have just built an ergo using a nuvinci hub on the fly wheel 30kg and there is play in the hub if the flywheel is rocked side ways. Is this play normal? Is it possible to get a service manual for these hubs?
  • 31 Answers
Tighten the cones eighter side?
Posted on Jul 23, 2009
John deere stx38 no spark
1. check the woodruff key on the flywheel for play, 2. check the magneto with a meter to see if it is bad. 3. Check the magnet strength in the flywheel. 4.check the gap between the fly wheel and the magneto, The gap should be 010.
May 07, 2018 | John Deere Garden
Makes trobbing grinding noise when turning left
It could be a bad wheel bearing, and if so it probably is the passenger side, but check them both sides. Raise both wheels off the ground, or one at a time, and rock the wheel back and forth and up and down. The side with the bad bearing will have a lot more play in it.
To replace, the wheel "hub" with sealed bearing inside is replaced. The hub is bolted to the wheel knuckle, which supports the hub, the CV joint and axle shaft, the brake caliper and rotor, and the wheel itself. If you are experienced at car repair and have the proper tools, you can do it yourself. At a shop, expect a 2-4 hour labor bill, maybe under 2 hours if everything comes off easily. The cost of the hub and sealed bearing is probably less than $100, although prices can vary greatly.
May 13, 2015 | 1991 Cadillac DeVille
Flywheel position on nissan diesel 2.5
on the fly wheel. the bolt holes on one side will show where the fly wheel washers sat. if the tranny is out the way you can test fit it for both sides and see witch side lines up the best. and if there is factory paint markings on the fly wheel that is the side that needs to face the tranny.
Sep 03, 2014 | Cars & Trucks
I have a 2002 dodge grand caravan sport and I notice today that one of my wheel is straight and the other is slightly turned. My front wheels are worn out a little on the outer side. I think is my whe
It could possibly be the wheel bearing. Or it could be an inner or outer tie rod. To check the wheel bearing, jack up that side o the car and try to rock the wheel from top to bottom. If there is any play, the bearing is bad. I there is no play up and down, then try to rock the wheel side to side. Play here usually indicates a bad tie rod.
Dec 13, 2012 | Cars & Trucks
I have a 99 Dodge ram 1500 5.2L stick shift and the front end is making a pulsing grinding noise at 15-30 mph, it stops as soon as I apply the brakes or turn.
1) Could be a stone or something similar between the pads and disks on your front brakes. Wheel off check the disks are they pitted, rusted or scored. Look for stones or grit between pad and disk.
2) Could be a wheel bearing, jack up the car (Securely) see if there's any play in the wheels. Try to rock them side to side and top to bottom. If there's play (movement/judder) from the hub, your bearing needs replacing.
Feb 16, 2012 | 1998 Dodge Ram 1500 4WD
Model 917-372832 Eager-1 5.5 HP . Stopped running . Won't restart. I believe the timing may of moved. How to remove the fly wheel to check key position? The key may have stripped. Hit a rock which may...
Hi, you are correct, the key will be sheered. Remove the top shroud and flywheel nut, then while pulling upwards on the flywheel have someone strike downwards on the crankshaft with a hammer and brass drift. Do not use a steel drift as it will damage the crankshaft. Hope this helps, regards Phil.
Jul 18, 2011 | Craftsman Garden
I have a vibration in the drivers side front end..wheel bearing??
check the wheel bearing for play, just Rock the wheel, if the hub bearing is defective u will fell it, the other thing that can cause this is the CV joint being worn out due to a torn boot and the joint running dry
Oct 21, 2010 | 2005 Pontiac Grand Am
I have a ford explorer 2004 /2005, and is given this heavy noise at the front wheel while the there is an increase in speed,what are the signs of a hub bearing, because i am suspecting the front hub...
The best way to check is to lift the corner of the vehicle clear f the ground and then with a trolley jack lift the lower wishbone to put pressure on the suspension spring. This removes any force on the ball joints and bearings associated with the wheel hub. Grab the wheel 9 o'clock and 3 o'clock and rock the wheel from side to side to side. If there is any slack or minor play you will feel it first and possible see and hear it. Now take the wheel in the 6 o'clock and noon positions and and again check for play. Now remove the wheel and apply the rocking motions again to the naked hub. You should be able to see any fault with the steering knuckle, the wishbone control arm ball joints and bushes along with any play in the hub bearing. The bearing should run smooth and you should neither feel or hear any roughness from the bearing. If there is a lot of play detected try this: Remove the locking pin on the main bearing nut and then tighten the nut until free rotation of the hub begins to become stiff. Now loosen the main nut by two flats only and refit the locking pin. Refit the wheel. When driving, a worn bearing is indicated by a persistent whining growl. On front wheels the noise often gets worse during a turn as the weight of the vehicle is transferred. While the wheel is off check the condition of the brake rotor ensuring there are no warps or cracks. A damaged rotor is indicated often by a thump thump sound front he wheel and this is accentuated and felt through the brake pedal when the brakes are applied
Aug 24, 2010 | Ford Explorer Cars & Trucks
Hi, How do you adjust float in steering wheel is it done at steering box or is there another trick Thanks Chris
WHat do you mean by "float in steering wheel"? Do you mean play at the steering wheel? If so, there probably are no adjustments on that car. Some older cars used steering boxes which could be adjusted, but Every Hyundai I've ever seen used rack and pinion steering which is usually not adjustable. You should check for play in the whole system. Have someone rock the steering wheel back and forth and look at the steering components to see if there is any play in them. If it is rack and pinion, hold your hand on the boots that are on either side while the wheel is being rocked to check for play in the inner tie rod ends. Replace any parts with play in them.
Nov 28, 2009 | Hyundai Veracruz Cars & Trucks
I hit a big rock with my walk behind lawn mower and now it sounds really bad when it is running. Whats is wrong with it?
the flywheel key is broken.take the recoil cover off.take the nut off that holds the flywheel on.thake a hammer and lightly hit the flywheel oppisit side of key way.the fly wheel will come off.replace the key.replace the flywheel.replace the recoil cover and test run the mower.should be fine.let me know if this helped................
Jun 29, 2009 | Mtd 22" Yard Machine Push Mower
Silver Jeans NuVinci Gearless Drive Hub 36H Silver Logo
59 people viewed this question
Top Silver Jeans Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Silver Jeans Cycling Expert? Answer questions, earn points and help others
