Garden Logo
Posted on Jul 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the setings for the carb? - Garden
Anonymous
Level 2:
  • Expert 155 Answers
  • Posted on Jul 25, 2009
Anonymous
Expert
Level 2:
Answers
155
Questions
0
Helped
91345
Points
316
Start at 1 and a quarter turns out from closed position
Tappet setings for mitsibishi l300 4g63 motor
valve clearances sohc 4g63 carb motor both hot and cold
Valve clearance - INLET mm: 0,15 hot
Valve clearance - EXHAUST mm: 0,25 hot
This engine is set hot if you are repairing the engine and have to do this cold
then set to 0.10mm INLET and 0.20mm EXHAUST
Then once hot readjust to specs
You did not answer my question.setings for 12.5 hp tecumseh
well because you what setting are you looking for --carb spark plug magneto/cdi if your more specific maybe some one with small engine knowledge might be on to answer your vague question and you have question listed under computers
Jun 20, 2017 • HP Garden
Just put in a new vwgolf 1300 carb did co setings went well for 2days then they idel drops on its own
first, have your carb overhauled. this simply means that it will be cleaned thouroughly.
next, have them fix your air/fuel ratio.
lastly, adjust your idle.
We need to get to ip protocol
to have access to network setings, need to connecto with the cabel firs, then if connect, the setings apear from the setings (IP , Gateway, subnet mask.)
1helpful
All 4 exhaust pipes from engines glow red after running 5 min.
this is an indacation that the motor is running too lean of the air fuel ratio. this is uselly caused by the carburators being partly clogged up and not allow enough fuel to flow through the jets. a good carb cleaning and re seting will likely solve the problem. Brian
Need the carb setings for a echo cs-510evl
Your OM follows;
http://www.echo-usa.com/pdf/documentation/CS510evle_010186.pdf
Carb settings are on page 14.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 25, 2010 • Echo Garden
2helpful
2answers
Suzuki Samurai Hitachi carb manual
Car 1994 Suzuki Vitara (Sidekick), 3 door, carburetor, petrol.
I need a hose diagram for the carburetor. The person who owned it before made a mess of the system so its not throttling steadily. Hoses are blocked off and I suspect hoses re routed.
Help me please!
Nokia 5800 phone switching off automatically when it is locked
maybe your mobile seting make like that , so check your seting again if not u can make default seting again like company resetings so probleam is off
1helpful
Yammy rd 200 1978 inconsistent running
check the neddle valve seats under the float bowls,may find that theseats are not sealing,to test,take the carbs off the bike,remove the bowls ,compress the floats untill they are all the way up(simulates full bowl of fuel)then blow through the fuel inlet pipe,you should not be able to hear air passing throgh the valve if you can replace the valve seat and the needle valve,sorry cant remember point settings,long time ago since i worked on one of these
Top Garden Experts
Jay Finke
Jay Finke
john h
