Question about Linksys Wireless-G WRT54G Router
No internet through router
I have cable internet and a linksys wireless G router. I have two computers, one running vista, one running XP. My internet quit working this morning. When I connect a computer directly to the modem, i get internet access. my computer will pick up the wireless router. but when I connect the modem to the router, my computer still will onyl connect to the router, not to the internet. I've tried resetting both router and modem 3 times and still the same results
    Problem Solver:
  • 12 Answers
There is a section in the router that says Status. In order to get to the router webpage, choose your start button and then choose Run. From there you want to type in the letters:
cmd
and then press the OK button
When the DOS like box opens, type in
ipconfig /all
Notice the line that gives you the Default Gateway, should have something like:
192.168.1.1
at the end of it.
Whatever the number is, mark it down. Connect your laptop or pc to the router. Pull up the 'web' and then try to visit the Default Gateway ip address instead of a website:
http://192.168.1.1
if it asks you for a user name and password, choose the password field and type in
admin
hit the keyboard enter key and see if you can get into the router web page. If you can, then check the status section and see if you have WAN or Internet connection to Comcast or Cox or whatever your internet provider is... it should NOT say 0.0.0.0
If it does, then you want to make certain that the cable from the MODEM to the Linksys router is going directly into the router's Internet or WAN port. If this is the case, consider using another cable. If that does not work, you may be better off buying a replacement router. I have always had luck with a Netgear wgr614. It does not give you the fastest, but faster speed routers often requires unrealistic upgrades, and it not necessary for daily use if this Linksys router has worked well enough for you in the past.
Additionally, know that these routers are sensitive to power surges and a SURGE PROTECTOR, not a power strip, may be the smartest investment you can have for both your pc and your modem / router.
Posted on Jul 01, 2009
How do I set up my router with out the disc? It won't run because it is Windows 95 not vista
if you connect the computer to the modem, does it work ?
If that works then the modem is working working properly.
now connect the modem and the computer to the router. open the set up page of the router.
here you can change the settings of the router.
You don't need CD to set up router
Click here to know more about how to set up router.
Jan 09, 2010 | Linksys Wireless-G Broadband Router
Cannot connect both XP computer and Vista to Internet
A lot of cable modems will store the MAC address of the first device connected to them and will only talk to this particular device/MAC address. If this is the case, you will need to power down the modem and the router for some period of time. If you also get phone service through your cable company then there may even be an internal battery backup that you have to exhaust. Unplug it and wait at least one minute after all lights are off and then turn it on first followed by the router. The router should then register its MAC address with the modem and then all will be good.
If your modem or some other equipment owned by the cable company permanently stores the MAC address then you will need to one of two things. The easiest is to call the cable company's tech support and ask them to change the MAC address for your account to match your router. The seoond option is to configure the router to clone the MAC address of your XP box. Here is a link to a thread on linksys' web site with step by step directions:
http://forums.linksys.com/linksys/board/message?board.id=Wireless_Routers&message.id=108261
Note: If you want to implement security, do not use WEP as indicated in these directions, use WPA. WEP is hardly better than no security.
Jul 14, 2009 | Linksys WRT54G2 Wireless Router
Wireless computers work fine, wired desktop extremely slow
On your old desktop, go to Control Panel > Internet Options > Connections > LAN Settings make sure no check on boxes there. Click OK and Apply. Click on General tab, click on Delete File (delete all offline content), Clear History and Delete Cookies. Click Apply and OK.
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless B Router Compatible with Windows Vista?
I would advise you to purchase a Linksys G router, Model # WRT54G2. Works well with Vista and your other laptops will work also.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 26, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
254 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
