Question about E-Machines eMachines Desktop PC
Computor speaker static
I have static coming from the comptutor speakers.
They been plugged ioutand then plugged back in.
How does the static goes away??
  • 749 Answers
Hi...
Have you tried "grounding" your cpu case to the ground or to a metal that has a connection to earth? try it...
Try also changing your multimedia speaker... that might be the culprit too.
goodluck... don't forget to rate... thanks
Posted on Jul 01, 2009
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
LEFT SPEAKER NOT WORKING. pLUGS IN GOOD, BUT NO SOUND OUT OF SPEAKER. cAN ADJUST VOLUME BUT NO SOUND COMING OUT OF THAT SPEAKER
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 06, 2011 | JBL Spyro Computer Speakers
My woofer and speaker make a lot of static and one speaker does't have any sound, it seems that when I move the blue connection the one from the speaker to the woofer the woofer gets louder and so does...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 29, 2011 | Boston Acoustics BA745 Computer Speakers
Sound not coming from left speaker
try swapping the speakers around if the problem still persists either the speaker is faulty or the speakers plug/outlet is
hope this helps
Jan 09, 2011 | JBL CREATURE II Computer Speakers
Left Speaker Jack only produces static
Hi!
That is probably happened to an aging speaker.
Consider buying a new one or try to rewire the coil inside the speaker magnet.
Jun 01, 2010 | Bose Companion III Computer Speakers
There is static coming out of my speakers on my stereo. I I checke to make sureall the wires are connected properly and the power is plugged in securely. There is static with the sound on all...
Don't worry, it's more possible that you have the static electricity and through your stereo this electricity goes to the ground. Try touching another metalic surfasce (refrigirator, oven etc), try to change your shoes (especialy if your stereo is on a carpet floor and you walk on it) Sometimes when we are very nervous the static electricity on our body is higher. So keep calm.
Stelios.
Feb 20, 2010 | RCA WSP155 Main / Stereo Speaker
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
E-Machines eMachines Desktop PC Logo
60 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
