Question about Ovens
I need to convert a four prong into a three prong cord, I have the three prong cord allready, but it's not color coerdinated (sp) what do I do?
    President:
  • 1,136 Answers
Hi, The 3 prong cord should be set up with the ground wire in the middle and the lead wires on the outside. It will hook up that way.
Just make sure you put the middle ground wire on the middle post of the block and the outside wires go on the putside post. It doesn't matter witch side.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 01, 2009
How to hook up electrical? 220v single phase? What color wires on which connections of the plug?
Identify the prongs. If you have wired a 110-volt fixture or plug, then you are aware that the different prongs connect to different colors of wires. The same principle holds true for 220-volt plugs, and this is very important to keep from tripping the circuit breaker. A three-prong plug will connect to two colored wires that each supply 110 volts and a bare copper wire which is the ground. One of these colored wires will be black, while the other one should be red, white, or blue. The four-prong plugs connect to a black and a red wire that each supply 110 volts, a white neutral wire, and a bare copper ground wire.
Read more : http://www.ehow.com/how_6830969_wire-220_volt-ac-plug.html
How to Wire 220 Volt AC Plug eHow
Dec 16, 2015 | Ovens
Tip
Oven Cord and Wiring Oven for 3 Wire or 4 Wire
If you have an Electric Oven, Range, or Cooktop and need to change the style of cord that you have on the appliance or if you just need to install a cord on a new cooking appliance, you may have questions about where the wires need to go. This tip will help you to figure these questions out.
Remember to ALWAYS make sure that all power is disconnected BEFORE beginning your work!!
On the back, underneath, or on the side, of your range or oven will be a cover plate that will have the wiring connection lugs behind it. A screw or two will need to be removed to expose the connection point. Always remember to reinstall the cover after you have finished your connections.
If you have a 3 wire cord the plug will look something like this.
You will have a red wire, a white wire, and a black wire, on the other end from the plug.
The black and red wires will go on the two ends to the matching colors. The white wire will go in the center. If you have a bonding strap make sure that you jumper that from the center lug to the frame of the dryer. If you do not have a bonding strap, then make sure to make one out of #10 ga. or larger wire and a couple of crimp rings. Green wire is preferable.
The connection will look something like this.
If you have a four wire cord the plug will look like this
Here again, you will have the red, white, and black wires. This cord will also have a green wire. This wire gets connected directly to the frame of the appliance. With this cord, you do not need the bonding strap or wire. If you are converting from a 3 wire to a 4 wire then remove the old bonding strap if there is one there.
This connection will look something like this.
When converting from a 3 wire to a 4 wire you just REMOVE the bonding strap or wire and hook the green wire to the frame. If you are converting from a 4 wire to a 3 wire then you ADD the bonding strap or wire. It gets hooked from the center lug to the frame.
Always make sure that the outlet that you are plugging into is wired correctly also. The black and red are each 110 volt legs that have a voltage of 220 volts across them. The black and the red wires need to be wired to a double pole circuit breaker of the required amperage. The wiring needs to be large enough to support the breaker size that you use and the requirements of the appliance. For 30 amps. use 10 ga. wire, for 40 amps use 8 ga. wire and for 50 amps. use 6 ga. wire. The white or neutral wire goes to the neutral bar in the power panel and the green wire goes to the ground bar in the power panel.
By following this tip you should be able to hookup a new appliance or convert your existing appliance cord. Recheck all your connections before turning the power back on to the appliance.
http://www.fixya.com/support/r4319770-maintenance_range_stove_or_oven
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Apr 06, 2010 | Ovens
Oven locked with door open how do I reset it?
my first thought is if the oven is standard 220 three or four prong electric, for safety, go to breaker switch panel,"in House or outside of house", open pannel door and find the breaker switch marked for "oven" or "kitchen utility" . it will be a double switch of 20 to 25 amp ,"each". or it will b One breaker switch of 45-50 amp. ,switch it to off. then see that the oven has no power, the stove top as well as the lights and the oven .try to unlock it now. by lever or button ? then if not unlocking turn the breaker back on and try it again. hope it works for you.
Mar 29, 2015 | Ovens
Hotpoint oven manual
I found that GE offer a specific plug which allows four connections:
Universal range power cord (4W / 4' / 40A) WX09X10035
You may need to find out if you have such a socket or how to produce such a socket.
Dec 18, 2013 | Ovens
I HAVE A FRIGIDAIRE GALLERY RANGE WITH A 3 PRONG, BUT NEED A 4 PRONG, WHAT DO I DO?
You can go out and get four prong plug and wire according to the directions on the web site below.
If you feel this has been helpful please give me a comment...Thanks!...Jim
http://www.appliance-repair-it.com/range-cord.html
Feb 13, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I am replacing a 4 prong cord which is red, white, black, green with a 3 prong all black cord. My stove is a Maytag which was originally wired with a 4 prong pigtail for use in a trailer. I want to replace...
Okay, without knowing everything I would need to know; here's what I propose you do. First of all, are you exchanging the same wire size cord (eg. #12 stranded wire for 20 amp, and #10 for 30 amp, #8 wire for 40 amp,  # 6 for 50 amp, and so on) for the same application (ie. 30 amp for dryer, and 50 amp for range, etc.) ?  Let's say you are, so what you want to do is take the 4 prong off (one by one), and write down the configuration and color, as you take off each wire. And then you're going to apply this to your 3-prong plug. So, without seeing the plug and its application - I'm going to explain to you how to wire this. First, put the black (hot leg) wire will go on one of the straight prongs - and the red (the other hot leg) wire will go on the other straight prong. Now cut the white wire down to about an inch, so it can fit into the plug when you're putting the cap back on. And remember to tape this white wire with electrical tape. This is for many reasons, but its basically for safety. Now, the remaining wire (green) goes to the right-angled prong - which is your ground wire. Now your wired for 240 volts, and depending on the size of the wire - your wire size shall be in accordance with the amperage that I explained earlier. Now make sure that your power is off at the panel before you plug this oven plug into the wall. Then, turn the breaker on, then off. If everything seems okay, plug the cord into the wall (with the oven off) - and then turn the breaker back on. Then proceed to turn your oven on from there, and then if everything checks out okay, then your good to go. Good Luck with this, and I hope this works out for you. If not, feel free to contact me again. - Jim
Apr 05, 2010 | Ovens
Frigidaire self cleaning stove mod FEF369cgsb ser vf94422321 was originally wired direct and it shows 4 wires. Now I want to use a plug and outlet, 3 prong. How do you connect the 3 prong plug? thank you...
Vivian
the original wiring probably had a red, white, black, and green wire. It is 240 volts. The red is hot, carrying one leg of 120 volts. The black is also hot, carrying 120 volts. The white is neutral, and the green is the ground.
I am against altering this, but you can wire the red and black each to a hot leg, and wire the white and green to the bottom ground. This then introduces a ground wire to your neutral bar in the circuit panel, which is not the best way to do it, but will work.
Best to get an electrician to wire a 4 wire cable to a four prong outlet, and then use a four wire pigtail with a 4 pronged plug.
Lots of people modify it, they ground the green wire to the stove, where the wire originates,and to the box with the outlet in it where it hooks onto the plug if it is metal. Then you have a part ground. And that is assuming you have a cable with wires sticking out to wire to a plug.
Boils down to your decision. If the above isn't the case, get a four pronged outlet and wire the red and black to the top two prongs, the white to the neutral, and the green to the metal box it sits in.
Sirwriter
May 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
3 prong outlet/4 prong plug
If you bought an electric range , it is a 220 volt range with a BIG plug and can only be used in a 220 volt outlet.
If you can plug a small appliance into that outlet then the outlet is only 110 volts and you need an electrician to run a new 220 line!!!!!!
Was the range you are replacing a gas range??? If so that runs on 110 volts like you TV and toaster and every other small appliance in your house!
If you are not sure what you are doing get a professional to help you!
Every year in the United States thousands of people die buy trying to fix the electrical in their home alone!
BEWARE 220 Volts will shock you! BUT USUALLY will kill you if you touch it!
ngafm
Please rate me on this site before you sign off!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!liance in your house!???????????????
Sep 06, 2008 | Ovens
110v Range cords
Most duel fuel ranges need 220 volts. and the outlets are different.
If you can't find a heavy standard real range cord it is because in your area they probably changed the code. Try ordering out of state from Home Depot E bay etc. Or change the outlet.
Jun 16, 2008 | Ovens
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Ovens Logo
46 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
