Question about Kenmore Dryers
My dryer wont heat up...It runs but will not get hot.
  • 537 Answers
Http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
http://repair2000.com/noheat.html
Posted on Jul 01, 2009
  • 1,056 Answers
Check all the thermal breaker at the back. If they are good then the dryer heating element may have opened.
2 Suggested Answers
  • 120 Answers
SOURCE: dryer quit getting hot
Either the elements have broken down or the gas burner has shut down, depends on your model.
Posted on Oct 09, 2009
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Nov 22, 2016 | Hoover Dryers
Dryer will run about 10 minutes then shut off. Try to turn it back on and it just will buzz
Either a motor with bad windings,. or an over heating problem?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
GOD IS GOOD !!!!
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 30, 2014 | Dryers
Why dose a eletric kenmore dryer 70 seires the dryer runs about 1minute then turns off
Bad motor windings OR
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Jun 22, 2014 | Kenmore Dryers
The timer will not advance and wont get hot
if the dryer is only getting 110v instead of 220v it will run but not heat check your power and breaker
Mar 23, 2014 | Crosley Replacement Clothes Dryer Thermal...
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
Wont heat on low heat only on high heat and keeps running
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 15, 2011 | Whirlpool Dryers
My Roper rel3612bw2 will only warm and not get hot. The heating element was replaced around three years ago. Could it be the heating element again or a thermostat control or something else?
I would disconnect the vent tube and run the dryer and see if it gets hot, if it does then it is a restricted vent. If not then I would check these items:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Jan 29, 2011 | Dryers
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Dryers Logo
88 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
