Question about S3 Nirve Fifty-Three Men's 3-Speed Automatic Shifting Cruiser Bike
1st gear always falls out into second gear when i peddle even a bit hard. 3rd gear is always fine. Is the pin inside the hub usually bent. This bike is fairly new but the bike shop is now closed.
  • 2,359 Answers
There is a re-call on some Nirve model.
CHECK LINK HERE for more information.
Posted on Jan 05, 2011
  • 1,056 Answers
Loosen the rear wheel and straighten them out.
Posted on Jul 01, 2009
  • Ronado Panaligan
    Ronado Panaligan Jul 01, 2009
2006 Kawasaki ZZR 1400 won't shift
Hi, Edward and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
won shift up to 2nd
Shift Lever is stuck Cant get past 2nd Kawasaki Forums
Kawasaki 2007 ZZR1400 Service Manual
OEM Parts for Kawasaki
Kawasaki ZZR1400 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 10, 2017 | 2006 kawasaki ZZR 1400
Why does it have trouble shifting into 3rd gear?
Hi, Joe and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shifter forks sprung.
7. Transmission oil too heavy.
Good luck and have a nice day.
Aug 16, 2015 | Motorcycles
Wont engage in 3rd gear
Bent shift fork is your problem.1st and 2nd working fine,wont go into 3rd,replace the shift fork and stop being so hard on the shifter.Costs a lot of money to fix these toys.
Apr 14, 2014 | kawasaki KX 250 Motorcycles
2002 Suzuki Marauder VZ800 Front cylinder does not fire till bike warms up a bit?
Definately try a spark plug first. What does the old spark plug look like? ( white, oil fouled, melted, metallic?). Usually a fuel issue will make the inoperable cylinder very hot. Might have a loose valve guide in the head, or a bent valve.
Oct 18, 2012 | 2004 Suzuki VZ 800 Marauder
Shifted into second gear, heard a popping noise, now the car wont stay in 1st, 3rd, or 5th, nor reverse, it will drive in second, and fourth, but you have to hold the shifter down as hard as you can, and...
The pin on the shifter pops loose. REPLACE THE PIN!!!! The dealer just clipped it back on and it did it on mine bunches of times - til they replaced the pin. (Don't know about the popping sound, it just let go on mine, with the same exact affect).
Jun 13, 2011 | 2004 Chevrolet Aveo
2006 Honda VT 750 Shadow will not shift from 2nd to 3rd
Hi, Dennisellis3 and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
infamous third gear Honda Shadow Forums Shadow Motorcycle Forum
the infamous 2nd gear popout
Honda VT750C2 Shadow Spirit Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
May 16, 2011 | 2006 Honda VT 750 Shadow
Gear shifting is too tight
Hi, Nirmal_nettu and the usual suspects are:
For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/bajaj+pulsar+150
Apr 27, 2010 | 2005 Bajaj Pulsar 150
3rd gear har d to put in
Im not sure how you ride your bike but if you "beat on it shifting without cluch sometimes the fork in the transmission gets bent...this is the only reason that would cause hard shifting besides wrong gear lube
Dec 10, 2009 | Hyosung GT 650 R Motorcycles
I can not shift out of 1st and 2nd. I can shift from 1st to neutral, and 1st to 2nd, but I can not go from 2nd to 3rd. When I depress the clutch and pull up on the shift lever to go from 2nd to 3rd it is...
Sounds like a bent shift fork of broken dog gear. Try cleaning the inside of trans with part light oil and solvent. (not fuel) Rock bike a few times and shift gears, Do not start. Keep doing so untill shifting gets easier. If this does not work. Try starting it one time and shift easy. Do not force. Still no luck - Split cases and repair
Oct 13, 2009 | 2003 Yamaha YZF-R1
Falls out of second gear and only second gear, after it falls out a couple times it bends a tab on the linkage rod and will get stuck in neutral. i've already been in this bike to get it out of neutral, ,...
the yzf600r has a large gap between 1st and 2nd gear. if you don't shift into second firmly every time, what happens it that over time the dogs which engage 2nd gear gets worn/rounded off, and the "falling out" starts to occur during hard acceleration in 2nd. once the problem is there, the only way to fix it is to replace the affected gears: 2nd and 6th ( the gear 2nd slides in to), the shift fork, and the shift cam.
this requires a complete teardown and splitting the cases. about $3-400 in parts, depending on where you purchase them, and 8-12 hours labor depending on your level of expertise.
a qualified shop would charge $1500-2000.
Jul 24, 2009 | 2002 Yamaha YZF 600 R thunder cat
S3 Nirve Fifty-Three Men's 3-Speed Automatic Shifting Cruiser Bike Logo
114 people viewed this question
Top S3 Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a S3 Cycling Expert? Answer questions, earn points and help others
