Question about Whirlpool Duet GHW9150P Front Load Washer
  • rogersju Feb 01, 2008
    Where do you find directions on how to remove the pedestal?
What i wrong when you use your washer and it smells really bad!!
I mean like there is water in it that hasnt drained or something??
Posted on Nov 04, 2009
  • 66 Answers
If you pull the draw out and lay the washer on the back you will see the 4 SCREWS to loose . if is not too late for you
Posted on Dec 23, 2007
How do I detach my Bosch drier from yhe stacking kit as I need to replace the drier
most model have some bolts or screws to keep dryer safe on top of washer
just remove bolts and screws and pull back the dryer
Feb 11, 2015 | Bosch Washer And Dryer Stacking Kit...
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Sep 28, 2014 | Electrolux Washer/Dryer Laundry Pedestal...
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
I want to try to put my washer (Frigidaire FTF model) on top/bottom of my dryer (also frigidaire). However, we didnt receive any brackets which are standard for stacking, so we are curious to how to stack...
Hello the advice about removing the top of the washer and bolting the dryer to it is exactly what to do.Under the washer top is built in brackets to do that.Every front load Frigidiare washer leave the factory pre-equipped to stack the dryer to it by removing the top and bolting the dryer to it
Aug 21, 2011 | Frigidaire FTF530FS Front Load Washer
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
Jan 01, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Removing a pedestal from plasma tv
If you check on the bottom of the pedestal there may be 4 screws inside the bottom to where once removed you might be able to slide off the pedestal
Aug 04, 2009 | Televison & Video
Remove stacking kit from Bosch tumble dryer
I have got the same problem - did you manage to fix it?
Mar 24, 2009 | Bosch WTA4410US Dryer
Very loud after stacking.
I assume you used the kit for stacking and removing the top of the washer and installing the plates?
You might need some sticky rubber pads to stop metal to metal contact and some duct tape around the vent exiting the dryer where it meets its back panel. This is common, you could go specific or browse ace hardware and find a compatible source.
Sep 10, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
285 people viewed this question
Dan Webster
Dan Webster
Sal De
