Question about LG LSC26905TT Side by Side Refrigerator
Humming sound? motor or fan constantly running
But it stops when you open the door? Otherwise its constant loud humming from fan / motor?
  • Anonymous Mar 23, 2014
    Cafe, loud constant noise
    President:
  • 1,136 Answers
Hi, It is the evaporator fan motor you are hearing. The motor is the only thing that shuts off when the door is open. The fan motor is located behond the rear panel inside the freezer sections.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 01, 2009
Loud humming noise coming from fridge
sounds like the evap fan is hitting something.. or is loose and making noise... I would remove the cover in front of the fan and take motor out and reinstall it making sure all washers and grommets are in place...but I would look for ice build up first, this could indicate a defrost problem..... hope this helped ken
Sep 29, 2014 | Bosch Refrigerators
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
Oct 20, 2011 | Microwave Ovens
My Reddy heater torpedo multi fuel heater won't start this year. It makes a loud humming noise for a minute or so and then nothing. If I try starting it a few times in a row it will make the noise...
Remove the top cover and rotate the fan by hand. If should turn pretty easily. If not may you can put some oil where the shaft passes through the ends otherwise you will need a new motor. If the fan turns easily then the capacitor is probably shot. I don't know if you can get the capacitor seperate from the motor or not. There is a small low pressure compressor attached to the back of the motor. Your problem may also lie in there. The covers come off easily so you can check it out.
Dec 29, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
Both the refrigerator and freezer are set to the recommended temperature, however, the refrig unit is making a loud humming sound. This sound stops when you open the door, but begins again when it is...
There is a fan that blows cold air into the refrigerator. It usually stops when the door is opened. Check to see if it might be frozen with ice if the humming sounds abnormally loud. Usually if it freezes up you cannot hear the fan running and the refrigerator will not get cold enough.
Aug 25, 2009 | Refrigerators
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Constant humming sound
the most common problem with ALL microwaves is the magnatron
Dec 29, 2007 | Samsung SMH7178STD Microwave Oven
LG LSC26905TT Side by Side Refrigerator Logo
891 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
