Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Won't heat It is not heating and can't find my manual I am wondering if I could get a manual to find the heating elements.
  • 999 Answers
Http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDE9700AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00003&componentDescription=BLOWER-HEATER-MOTOR&documentId=M0702017&backToLink=Return%20to%20Sub%20Components%20list
eric
Posted on Jul 01, 2009
How long will it take Rheem solar hot water to heat up
read manual:
http://www.rheem.com.au/Assets/1294/1/Rheemsolarlolineelectric511series.pdf
Usually electric element heats about 20 gallons per hour.
It appears the element is controlled by thermostat and automatically kicks ON when tank falls below thermostat set point..
This will be handy since element will continually heat the circulating water when outside temperatures turn cool... of course it will also be wasteful if thermostat is set high.
Jul 11, 2013 | Water Heaters
My Kenmore Elite 110.62932100 won't tumble or heat up.
try the homes 240volt circuit breaker it may not show its tripped but one of the 2 phases can trip out, (just reset the breaker) and if this happens either the dryer drum motor will turn or the timer will run, but not both as these 2 components each use 1 of the 2 phases 120 volts to run,but the heating element needs both 120volt phases for 240volts for the heating element to heat,this is what your issue sounds like to me,hope this helps
Dec 09, 2012 | Dryers
Fuji lamipacker lpe6510 won't heat up
Hi wondering if you were ever able to fix and if so how? Same thing just happened to ours at school and it is out if warranty period. Thanks.
Aug 24, 2012 | Cameras
Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Feb 07, 2012 | Dryers
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Frigidaire dishwasher won't dry dishes. Less than two years old. Seldom used. FDB1100RHM. Could this be the heating element? Could this be something we could fix?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2011 | Frigidaire Dishwashers
Gas dryer kenmore elite runs but won't heat
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 16, 2011 | Dryers
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
HEATING ELEMENT
hi follow the manual: http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8574093.pdf if it dosent work then as you mentioned the heating unit is bad you can replace it by yourself by buying it and insalling it its easy as installing a lamp but you can call for help (number in the manual) good luck
Mar 21, 2006 | KitchenAid 24 in. KUDI01IL - Multiple...
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
304 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
