Question about Hitachi 65F59A Television
Hitachi 65F59A TV No Picture or Sound Constant Red Power light
I have a Hitachi 65F59A TV. We turned it off one day and it was working fine. Tried to turn it back on and you can hear it turn on but no picture and no sound but the power light is a constant red. Wgat could be wrong?
2 Suggested Answers
praky16
  • 744 Answers
SOURCE: I have a Hitachi 65F59A TV. We turned it off one
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 01, 2009
I turned my hitachi tv on and i have no sound or picture what can i do ?
Are you getting the red led light? If not, please check the power outlet for any loose contacts. Try the TV on some other power outlet. If the TV does not work still, cool it off for 48 hours, after removing the plug and retry.
Aug 16, 2012 | Hitachi Televison & Video
No picture no sound, red light on, left unplugged over-nite, no change. Turn on/off a number of times, got back perfect picture/sound. Turn off, same problem, no picture/sound, red light on. Tried...
First if the model number is right here: When the red light is on about 80% of the set inside is powered up and running all out.
On these sets if you turn it off and the red light does not go out one of the relays on the power board is engaged or stuck in the closed position.
If I remember this model it has three black rectangular plastic relays on the power supply board(follow power cord into the set to see if this is the case.)
Relays have voltage and type marked on top (like 12 vdc etc).
Carefully with back removed what I would do is with something NOT metal tap on each relay until (with set turned off) the red light goes out.
That is the bad relay----if set has 3 I usually replace all as only 4 solder connections each and they are not real expensive.
I saw one of these sets where the customer had been gone for a month and when she returned set appeared to be off but Red light for power was on.
The set was so hot I tapped on the relays and then when I knew which was bad shut the set off and unplugged it to let it cool off.
I am saying if you leave the set plugged in and the red light is on There is the chance it may overheat to the point where you could have a fire.
Let me know if you have questions.
SD TECH
Sep 26, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Sunday night there were electrical problems with the power company. the power into the houses was so low, only the little night lights worked, the power would spike, but go low again before finally going...
During power fluctuations any thing could happen to semi conductor devices. Now the problem may be
SMPS components or other processor circuit fault!
Oct 12, 2010 | Hitachi 65F59A Television
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi Ultravision won't turn on
it is the power board in the tv hase some bad capasators in it but can cost some money to fix if unsher how to do it on your own if you live in central new york i do have my own shop and im cheep but i can not warenty any thing but i can help 315-280-0508 storm electronics ask for corey
Aug 04, 2009 | Hitachi UltraVision 42HDS52 42 in....
No Picture on a Hitachi 42EDT41A
Then it is probably not cold solder joints. You wouldn't think that an lcd TV would need a high voltage transformer but it does. They are very small compared to CRT televisions but they power up the screen. Without it you have no backround light to veiw what is there. There are two neon lamps on either side of the screen but they rarley go bad. My guess is the transformer ot the power supply feeding it.
Jul 25, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
thank u!!!
rate me
Jul 01, 2009 | Hitachi 65F59A Television
Hitachi 60EX388 Rear Porjection TV
i think its the fan that needs to be replaced. or it could be the bulb.
Try to open the bulb assembly unit and take out the bulb and put it back in. If you have an extra bulb, replace it and see if works. This worked for me. The bulb i bought wasnt compatible
Mar 02, 2008 | Hitachi 60V500 60" Rear Projection...
Help
Sounds like a blown fuse in the power supply
Jan 18, 2008 | Hitachi 57S715 57" Rear Projection HDTV
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 65F59A Television Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
