Question about Toshiba TP61G90 61" Rear Projection Television
Picture is blurry, but perfect sound
For the last month my tv picture sometimes comes on full of horizonal stripes. But when shut off and turned back on it is fine. Today it will not come on right, no mater what I do. Please Help experts!!!!!!!!
Sounds like a ground leg on the distribution block has loosened up and is not properly grounding the screen drive. worst-case scenario is that ione of the tubes (3 picture tubes) has started to short out and is causing the blur.
Posted on Jun 04, 2008
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 10, 2014 | Samsung DLP HL-P5663W 56" TV
Hi, I have a Hitachi 53 UDX that was working perfect and then I turned on my system which turned on the tv which came on, but then screen went out....Now I have a squashed looking oval picture that comes...
Have you checked all of your cables to ensure all are connected properly and are tight? If you disconnect your 'system' (which I'm guessing is an audio system?), does the TV work correctly?
Sep 02, 2011 | Televison & Video
I have a Misubishi WS-55513 55 in. Rear Projection HDTV Television.. I replaced the capacitors last month on the DM board and it worked perfectly. Now the tv turns on but the picture is black and there...
probably need to check those connections to the dm board, hopefully one is somewhat loose. reseat all those and hopefully the prob will be solved. you can also reseat the doubler board (it sits in the shield upright in the middle of the signal board, just to the right of the dm board) ... all the pic is processed by that doubler board. let me know if I can be of further assistance.
Sep 08, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Black screen and no sound
I realized that there is a 90 day warrantee on parts and a 30 day limited warrantee on labor for the  repairs that were done. As I stated, the original problem was the picture shrinking after a few minutes of the set being on. The repair firm took my control board with them. When they came back to install the repaired control board in my set there was a load spark during the installation, after which I had a black screen and no sound.  The repair firm took my set them and installed a "CAP Kit", a STRM6511, and a "D1881". The set worked perfectly until two days ago.
I called the repair firm an they are coming out this Thursday to check out my TV.   I am hoping the problem is related to the failure of one of the parts installed to fix a similar problem which occurred after the sparking incident.
Mar 31, 2008 | Mitsubishi CS-40505 TV
TV shutting off
try this part first 5600110347 you can get it at
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Televison & Video Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
