Question about Plumbing
I am looking for a water pump about 1/2 hp with it motor at a cheap price.
  • 832 Answers
Connect to the internet and type at search:
http//www.northerntool.com/webapp/wcs/stores/servet/product 6970.7736.
Since you did not specify the intended usage; you can choose from this website. (For deepwell, booster, sump,
etc....) Hope you will find what you want.
Posted on Oct 29, 2009
I woke up to no water my pump kicks on and hums for 3 to 5 seconds and quits
It sounds like it is seized with the overload relay cycling it to save the motor. It needs to be dismantled, cleaned and possibly rebuilt. Check the price of a new one it may be cheaper.
Feb 08, 2014 | Utilitech 1/2 HP Convertible Jet Pump...
Looking for the h.p. of my pool pump.
There should be a label on the motor and should look something like this.. There, you will find the horsepower of the motor... H.P. 1/4, 1/2, 3/4, or 1?????
Aug 10, 2011 | Intex Automatic Salt Water System for ...
Have a Honda Gc series 2.0 Gpm 4.0 hp gas powered pressure washer model 01195-0 that the pump has went out in and am having problems finding parts ( seals and unloader valve ) I have googled but no luck...
Honda has nothing to do with this pressure washer, other than it has a Honda motor. It is made by Generac. The pump is a cheap pile that can be replaced with a horizontal mount AR Pump for a decent price. The pump that came on the unit is not worth rebuilding. Try looking for an AR Pump RMV2G25 as a replacement.
Apr 01, 2011 | Honda Garden
Looking for a timer to turn a 120volt 2amp water pump on for 1min 2 times aday that will last for more than 3 years please help
1) You need 120V timer to control 2 amp water pump.
V x A = watts so 120V x 2amp = 240 watt
754 watts per HP divided by 240W = 1/3 HP horsepower.
2) To get 1 minute time periods, you need electronic timer.
Most electronic timers have minimum 1 minute set time.
Same schedule each day, you can use 356-day, 7-day or 24-hour electronic timer.
3) To have electronic timer last longer than 3 years you need a clean circuit and expensive timer.
Use circuit analyzer to check circuit. Hire electrician to check circuit and replace pump if necessary to make sure timer will last as long as possible.
4) Intermatic ET70115C should last for many years. Battery is replaced every 8 years.
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
ET70115C $379
http://www.1000bulbs.com/product/3391/ELEC-ET70115C.html
5) You posted under EH10 water heater timer, which is inexpensive water heater timer rated for 1HP. You can't expect inexpensive timer to last as long when using a motor, although 1/3 HP is lightweight motor.
6) You can buy five EH10's for same price as one ET70115C.
7) List of ordinary electronic timers, each with slightly different features
Intermatic EH10 $73
http://www.amazon.com/Intermatic-EH10-Electronic-Heater-Indoor/dp/B000GHIPOA
Intermatic ET1105C $96
http://www.amazon.com/Intermatic-ET1105C-Hour-Electronic-Switch/dp/B002X1FYWI
Intermatic ET101 $101
http://www.westsidewholesale.com/24-hour-programmable-electronic-timer.html
Tork EW100B $177
http://www.1000bulbs.com/product/8434/TORK-EW101B.html
Sylvania SA300 $72
http://www.amazon.com/Sylvania-SA300-120-Volt-Single-Pole-Industrial/dp/B000KKNEO4
8) See wiring diagrams and manuals for some of the timers listed above:
http://waterheatertimer.org/Boxtype.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Intermatic 7 Day Electronic Timer Eh10...
Need to find a link to the owner's manual/ repair manual for the Grundfos up10-16 b5/atlc......
Following link shows links to grundfos and grundfos manuals.
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
1) My grundfos stopped working because sediment clogged the pump, and the motor slowed.
When motors slow, they get hot and burn up.
I ask my friend who rewinds motors how to fix it, he said in the old days, they rewound every motor, but today they throw valuable scrap into landfill, and then buy new motors from China.
I told him not to retire, but go to school and teach kids how to rewind motors, and then took apart the grundfos line and cleaned it out with CLR, but it never worked again.
2) If timer stops working, but pump still works, you can buy cheap plug-in timer and connect grundfos to the cheap timer
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 23, 2011 | Grundfos UP10-16B5/ATLC Comfort Series...
I have an Aermotor nonsubmersible pump rpm 3450 1/2 hp model # c48b48c09 for my cistern. I thought I was out of water as I could only hear the pump humming and my washer only filled 1/2 up...but I am not...
It sounds to me like there is a hole rusted through the discharge pipe of the pump. If you are able to
look into the cistern with a flash light while the pump is running. You might see water swirling around
the pump. This means the pump is good, but the pipe is bad.
Nov 04, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I replaced my motor 1 yr ago and all worked fine...now the low speed works but the high speed only makes a humming noise.
SOUNDS LIKE A DIRTY START SWITCH OR CAPICITOR. THES MOTORS ARE NO JOKE AS I'M SURE YOU ARE STILL FEELING THE PAIN OF THE PURCHASE PRICE.. LOOK FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING ,USE YOU ZIP CODE ..
I WOULD HAVE THIS TYPE OF MOTOR SERVICED EVRY YEAR ! 1ST TIME ABOUT 80$ NEXT YEAR 40$ WHAT I CHARGE..
DON'T TAKE THE CHANCE HAVE A PRO LOOK AT IT, THERE TOO EASY TO SCREW UP .$$$... IF YOU UN-HOOK THE WIRES TAKE PICTURES OR WRITE DOWN WERE EACH ONE GOES !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!BEST OF LUCK..
HOPE I WAS OF SOME HELP, VOTE IF'N I WAS
Aug 07, 2010 | AO Smith 1 hp 3450/1725rpm 56J Frame 230...
How many horsepower does the krystal clear model 635 pool filter pump have
IF YOU PLAN TO REPLACE THIS PUMP , LOOK FOR A HAYWARD 1/2 HP SUPER PUMP. THERE CHEAP AND TUFF . USE YOUR OLD FILTER.. THAT MOTOR IS AROUND A 1/2 .. LOOK AT THE AMPS IT USES, ITS ON THE MOTOR . SAY 15 AMPS IS A 1HP AT 115 VOLTS
May 25, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Am trying to open pool, motor hums but will not run
Sounds like COULD BE something (a small stone or twig) jammed in the impeller. See if you can spin it using a long screwdriver, if it moves, it is not jammed. If it spins, I hate to say it might be the motor is gone.
May 23, 2010 | Sta Rite StaRite Duraglas Inground Pool...
Plumbing Logo
37 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
