Question about Canon DR-9080C Path-Through Scanner
HELP BIG JOB DUE TOMORROW! I have a DR 9080c and it just started putting two lines on the scanned pages. I have cleaned the rollers, the glass, run cleaning pages through even used compressed air to blow out everything. The lines are not phased... Any suggestions?
  • rallen1542 Jul 01, 2009
    I tried all of that and now the top reader only puts out solid black pages.
    The bottom reader is fine. Is there a "reset" on this scanner?
    Thank you for your help.
  • 490 Answers
Vertical lines are from dust on the Glass. Use Isopropyl alcohol, no solvents pls. Try scanning in diff contrast levels and if the thichness varies, it is confirmed dust on glass, whereas any fault in the reading unit will be constant and also have sharp edges.
S. Mohan, Chennai, India
Posted on Jul 01, 2009
Line down middle of scan
A line could be continuous scanning of dirt stuck to the glass or an error in the Sensor module. Please clean the glass thoroughly with Iso-propyl Alcohol. If the line has rough edges (varying thickness) it is definitely dirt on the glass.
Mar 05, 2012 | Canon DR-9080C Path-Through Scanner
When I scan a document in the canon 9080c scanner - the document when printed will print with a black line through the middle of the page or on the left side of the document. I have changed the rollers and...
Try scanning a few documents in full size mode (scannerrs maximum), If you observe a line in the same location in all images, you can conclude that there is either a scratch in the glass (due to stapler pins) or dirt stuck firmly. Try cleaning with Isopropyl alcohol. For absolute emergency, you can wet a cotton bud in after shave and clean the right spot, take care not to touch any other part other than the glass. If glass is scratched, you need to replace it.
Sep 14, 2011 | Canon DR-9080C Path-Through Scanner
We have a Canon DR-9080C scanner. When scanning in Duplex on pages with data on both sides, the back side of each page is coming out unreadably faint. The header and any overall large blocks of black on...
The Canon DR 9080C is a 'contact' scanner. There is no optical lens, instead it uses a technology called "Contact Image Sensor' or CIS. The page to be scanned must be close to the glass for a proper image. This is achieved by a full-length rubber roller just above/below the scanning module. The roller is spring loaded and in case it gets stuck, there wont be enough pressure on the document to keep it close to the glass. ensure these rollers are moving smoothly and if required clean them. The rollers are on the opposite of the Scanning module.
Jul 29, 2011 | Canon DR-9080C Path-Through Scanner
A line appears after scanning a page.
Please clean the glass with isopropyl alcohol, dont use solvents. Also clean the rollers with a damp but well wrung cloth.
S. Mohan, India
Jan 19, 2011 | Canon DR-9080C Path-Through Scanner
9080c fails to scan single page; has trouble scanning a batch.
Hi
what size page are you trying to scan, if they are smaller than the gap between the transport rollers, they will not feed.
the single sheet problem you have:- the scanner knows when there is paper to feed when the sensor is pushed up beside the pick roller and it will put the tray down again when the rollers are pushed up. sometimes the little plastic sensor to the left of the roller gets a bit stuck and needs to be freed, it wares itself out where it hinges inside the cover around the pick roller. just unclipping it and cleaning it is usually enough.
good luck.
Oct 07, 2009 | Canon DR-9080C Path-Through Scanner
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
I am scanning few document on canon DR 9080c and i observer there
This must be a vertical line and appearing at the same location on all drawings! Please clean the glass thoroughly. It must be dust particle sitting on the glass.
S. Mohan. Chennao, India
Jul 14, 2009 | Canon DR-9080C Path-Through Scanner
If I put a large amount of paper in my canon dr-9080cscanner, it only part of the page until ti gets to a specific part. For example I put in 100 pages and it scans the middle inch and a half until it gets...
I could not understand your problem clearly.
If I am right, you are saying that if you scan 100 pages, about 80 pages are scanned properly and the there is problem with the balance 20. Clean the rollers throughly with a damp cloth and also the ****** rollers. Please swithc of the scanner when you are cleaning the ****** rollers as they are in a 'locked' position in power on position.
If your problem is different, please explain it clearly.
S. Mohan, India
Jul 08, 2009 | Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
328 people viewed this question
old marine
old marine
