Question about HP Compaq Presario V2000 Notebook
Laptop shuts off without warning randomly
Compaq Presario V2069CL laptop just randomly turns off. I don't know if it is a thermal issue, a virus, or what but it is in good shape other than making its own mind up whether to stay turned on or not. Seems like it might happen more often when more applications are open but Im not sure. Virus scans don't show a problem and the fan does come on sometimes. Where do I start in finding the problem?
Any ideas?
  • 39 Answers
Re: Laptop shuts off without warning randomly
I know this may seem like a stupid question, but, is the battery charged good? Also, have you checked the contacts on the battery to be sure they are making good contact? Other than that, sounds like a thermal issue. Does the event viewer offer any explanation?
Posted on Nov 08, 2007
0 characters
3 Points
Compaq Presario CQ56-100SJ [XL580EAR] The clock keeps changing. I set the time, the timezone was already selected but everytime I look down, it's changed. After shutting down, it seems the time...
Assuming you don't have a virus, the laptop's internal (CMOS) battery may be bad. Apart from keeping the time current, it holds onto your machines bootlog. If the machine starts up in Safe Mode, it would likely be the CMOS battery that's bad.
Oct 18, 2011 | Compaq Presario CQ56-115DX Laptop
Turn on laptop. within minutes fan is running full bore and bottom is very hot
is this a new laptop? if not it may be that the fan needs a clean and new thermal compound needs to put on the cpu. if it within warranty i would contact compaq. You can do it yourself if you know what your doing but if you don@t then please don't try it as involves know how and if you mess it up you could have a dead laptop @ the end.
Feb 02, 2010 | Compaq Presario F730US Notebook
Compaq Presario 900 has been fine for 12 months since I bought it, but now shuts down without warning. It may be after a few minutes of operation or a couple of hours, it appears to random. It feels quite...
Computer shutting off after a few seconds to a few minutes
This sounds like an auto shut-off signal given by the processor because of a possible over-heating issue. This usually happens when the laptop has been run for an extended time without having the dust, dirt and debris cleaned from its cooling vents and grills. After time, the thermal paste on the processor bakes under the extreme heat and starts to flake off and lose its efficiency at cooling the processor.
Get a few cans of compressed air that you would buy at an office supply store and using short bursts, blow out the dust and dirt from all the ventilation grills and vents first, make sure the laptop is powered down and battery removed. Then, open all the compartments and clean them out as well including the cd/dvd tray. There is a small black hole on the dvd bezel, just stick an open paperclip in it and it will pop the tray open. Blow a good blast in there to clean the dvd player.
There is the possibility that the thermal paste will have to be replaced, that means you need to gain access to the heatsink and remove from the processor, clean all the old thermal paste from it and apply a small thin layer of new paste to the top of the processor and replace the heatsink, securing it evenly with the attached screws.
Nov 02, 2009 | PC Laptops
Compaq presario r4000 randomly hybernates
Go into the control panel and go into power management or power options and change the standby settings. Its probably set to go on standby mode after 30 minutes without use or something like that
Sep 18, 2009 | HP Compaq Presario R4000 Notebook
Laptop keeps shuting down at random.
This could be caused by MANY different things. If it is a random thing, where do you have your laptop when it happens? If it isn't on a flat smooth surface, it's probably a heat related issue. Laptops need a lot of air circulaton, through the bottom.
Jul 01, 2009 | HP Compaq Presario V2000 Notebook
Laptop Randomly shuts off without warning and keeps shutting off when I try to turn it back on.
You don't mention your OS, so here's some general info:
Please try to work throught some of HP's troubleshooter solutions given here and in links within that article.
Also of help may be this link and this link
Have a look at the event viewer and note the event error id codes that appear in conjunction with this problem, also note any specific error messages you receive and report back and we'll help you to sort it out. (event error codes xp)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 04, 2009 | Compaq Presario Notebook
Compaq Presario F700 Laptop power up issue
Remove your cpu/gpu heatsink, apply a ermal bonding, this will prevent shut off because of cpu/gpu overheating(chipset detects temperature faulty in the firsts seconds of operating your laptop), if this didnt resolve your problem, naybe and issue with your Mobo.
Please leave feedback
Apr 27, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq presario r3000
check the battery that powers your cmos. if your laptop is like my compaq armada, there's three screws at the top which free up the keyboard cover. there are three latches near the bottom of the keyboard. the keyboard swings up towards the top. there's two film type connectors in the middle of the motherboard. pull these out and the keyboard comes free. look in the upper left part of the laptop for a small disk type battery with a red and black on white nylon connector. replace this battery. it is a lithium-ion battery.
Dec 07, 2007 | Compaq Presario R3000 Notebook
HP Compaq Presario V2000 Notebook Logo
75 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
