Question about Brother SE-270D Computerized Sewing Machine
Bobbin don't turn
The bobbin stop turning
    President:
  • 1,952 Answers
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Posted on Jul 01, 2009
The sewing maching stops while it is sewing - makes a squeeling sound and has a E6 error message, but I don't see any thread anywhere that could be causing the problem
try rethreading the machine top and bobbin
make sure the bobbin is turned the correct way
try another bobbin
try a new needle-one that is for the fabic being sewed
if none of these suggestions help then it would be a good idea to
have the machine serviced
Jan 07, 2013 | Brother Sewing Machines
Threading the bobbin thread
try rethreading the machine top and bobbin--make sure to use every
thread guide
try changing the needle--make sure the needle is turned the right way
and inserted correctly into the needle holder
make sure the bobbin is turned the right way in the bobbin case
and if the machine still will not pick up the bobbin thread it would be a
good idea to have the machine checked to see if the timing is ok.
here is a link for a free manual just incase you don't have one
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Nov 06, 2012 | Singer 7258 Sewing Machine
My machine is baby lock.it suddenly got a problem.it is: it sews a few stiches and stops and it goes on like this
here are some suggestions, if the suggstions don't help then it
would be a good idea to have the machine check to see if something
in wrong with the computer part of the machine
1. change the needle--make sure it's the right needle for the fabric
2. rethread the machine top & bobbin,,make sure to use every
thread guide
3. make sure the bobbin is turned the right way in the bobbin case
4. clean under the needle plate & in the bobbin area for lint
Oct 12, 2012 | Baby Lock Sewing Machines
Error code c4
try these suggestions
if these suggestions don't help then the machine needs to be checked
Oct 06, 2012 | Singer 7258 Sewing Machine
My needle hits the bobbin case . How do I fix it?
Firstly check that the needle is in the right way, flat shank to the back and all the way up into the housing.
Don't run the machine, just manually turn the flywheel towards to you to check clearance on the needle, if it is still touching the bobbin case, then stop and take it for a service, the timing is out and will need to be reset by a tech.
Dec 07, 2011 | PfaFF Creative 7570
Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Problem with winding thread onto the bobbin (small free- arm Singer 100 sewing machine). Once bobbin winder shaft is pushed to the right nothing happens-bobbin rod does not start turning so I cannot wind...
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Aug 18, 2008 | Singer Featherweight 140Q
Brother SE-270D Computerized Sewing Machine Logo
176 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
