Microsoft Windows XP Professional With Servise Pack 2  for PC
Problem for Microsoft Windows XP Professional With Servise Pack 2...
Realtek HD Driver Instllation failure
By amitkjss on Nov 08, 2007
Nature of Problem:Realtek HD Driver Instllation failure
Intel Desk top board D945GCNL using XP Professional
With downloaded as well as Download CD it says"Realtek HD Driver Instllation failure"
Pls assist
amit
Comments:
Nov 09, 2007
- in Device Manager i am unable to remove it....& same issue in persist when i try safe mode installation....any other way pls.....
Clarification Request
Posted by kotugulo on May 17, 2009
Solution Link . . . http://www.microsoft.com/Windows-XP-Professional-With-SP2
Same Problem
May 07, 2009
-   Nature of Problem:Realtek HD Driver Instllation failure
-   prakashkj
May 06, 2009
-   Install Realtek HD Audio Driver Failure -   Guest
May 03, 2009
-   I have acer 5920G laptop. and sound problem I install realtech high difination drive but during installation error massage "realtek hd audio driver failure Problem"
Please me to slove this problem-   amol ghadge
Apr 14, 2009
-   unable to install realtek driver for intel dg31gl-   tomwaugh
Apr 13, 2009
Pls assist
kishor in Device Manager i am unable to remove it....& same issue in persist when i try safe mode installation....any other way pls...-   sysadmintkie
Best Solution
posted on Jul 29, 2008
Very Helpful)
rn3m
Rank: Apprentice
Rating: 97%, 9 votes
realtek HDA audio driver failure R1.72
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 07, 2008
Helpful)
sweet nancy
Rank: Apprentice
Rating: 94%, 8 votes
Nature of Problem:Realtek HD Driver Instllation failureIntel Desk top board DG31GL using XP Professional With downloaded as well as Download CD it says"Realtek HD Driver Instllation failure" Pls assist me as well as uploaded drivers frm net even its giving error
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jun 26, 2008
Helpful)
Russellreno
Rank: Apprentice
Rating: 92%, 2 votes
I had similar issues with my Realtek High Definition Audio.
  1. Realtek has a known conflict with the Microsoft UAA Bus Driver for High Definition Audio.
After I played with the M USS Bus it worked except the sound was two octaves higher.
I found these drivers and it now works
Was this helpful?
Yes
No
Solution #4
posted on Nov 08, 2007
Helpful)
MrJodie
Rank: Wiz
Rating: 83%, 91 votes
Realtek has a known conflict with the Microsoft UAA Bus Driver for High Definition Audio. You will need to find it in Device Manager and remove it before you install the Realtek HD driver.
If you still have a problem you may want to try restarting the computer in Safe Mode (to make sure everything non-essential, like virus-ware, etc., is shut off) and then install the driver.
Was this helpful?
Yes
No
Solution #5
posted on Mar 24, 2008
Helpful)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
any drivers from realtek won't work. just try ms uaa hd driver. i've seen this problem before and solved it.
Solution #6
posted on Dec 22, 2007
Somewhat Helpful)
bsrjth
Rank: Wiz
Rating: 82%, 357 votes
realtek audio driver is available in various versions . like HD audio , pci , simple bridge etc first of all identify ur configuration of realtek chipset in the mother boad by going to the mother boards comapny website nad downlaod suitable drivers
Was this helpful?
Yes
No
Solution #7
posted on Jun 19, 2009
Helpful)
chegemari
Rank: Apprentice
Rating: 88%, 2 votes
Although I had no issues installing the motherboard, a couple of things have to be considered:
1. If installing older versions of Windows XP, disable the dual processor mode in CMOS. Re-enable it after installation complete and all updates are applied.
2. Many users complain about sound not working. Fore the most part these issues are due to installation of this motherboard in to an older case which front audio outputs do not support HD Audio. DO NOT CONNECT FRONT AUDIO OUTPUTS TO THE BOARD IF THEY ARE NOT HD COMPLIANT. This will cause the signal to rear outputs being blocked.
Was this helpful?
Yes
No
Solution #8
posted on May 04, 2009
Somewhat Helpful)
BALERGOOGLE
Rank: Master
Rating: 75%, 3 votes
FIND YOUR SOLUTION DIRECT FROM MICROSOFT. YOU WILL FIND YOUR SOLUTION HERE www.microsoft.com/prob57ij52/solution
4102a12
Was this helpful?
Yes
No
Solution #9
posted on Nov 08, 2008
Somewhat Helpful)
PUKENGS
Rank: Apprentice
Rating: 80%, 2 votes
no sound
Was this helpful?
Yes
No
Solution #10
posted on Jul 23, 2009
Not Rated)
sabar2t
Rank: Master
Rating: 82%, 38 votes
Try this link . . . http://www.microsoft.com/Windows-XP-Professional-With-SP2
To find your best solution.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Windows XP
Questions and Unsolved Problems for Microsoft Windows XP
Do you recommend Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC?
Answer
Answer
i have hp 520 leptop my cd rom is not working and my win xp is currept then i wants install the... (More)
Answer
i am Ephraim from africa. my friend is one of the best footballers ever lived in this world i need... (More)
Answer
Computer bots up-yellow light on Mobo on-all fans power all seems normal,BUT i have a Nivida 8800GT... (More)
Answer
i am using windows xp to my computer the problem is that i cant use my jabra halo wireless headset.... (More)
Answer
i have a IBM laptop running XP Pro.i have a mifi card. it comes up in the list of wireless networks... (More)
25 Other Users Have The Same Problem - Continued
Comment by sachin7584, posted on Apr 11, 2009
Realtek HD Driver Instllation failure error code 0xE0000227
Comment by Guest, posted on Apr 09, 2009
I have the same problem
Comment by Guest, posted on Mar 03, 2009
Install Realtek HD Audio Driver Failure !! [JK]
Comment by Javed Kaleem, posted on Dec 27, 2008
The Realtek High Definition Audio Drive fails to install. And cannot be removed. I am using Windows XP Operating System. When I look at the Device list, no sound driver is installed and no sound is created by the system .
Comment by mmmpf, posted on Nov 21, 2008
i have the same problem. error message on install:
install realtek hd audio driver failure !! [error code : -0001]
i can't deinstall the driver also when i deactivate the the device, restart the computer and then start the computer in safe mode it doesn't work.
mmmpf@hotmail.com
Comment by Guest, posted on Nov 21, 2008
i have that same problem!
Comment by Guest, posted on Oct 23, 2008
i have the same plz
replay at my e-mail
midooo_tamer2008@yahoo.com
Comment by Guest, posted on Oct 21, 2008
same problem
Comment by Guest, posted on Oct 09, 2008
driver not installed in my pc
Comment by ojarhead, posted on Oct 07, 2008
my realtek high definition audio is out of date.now my pc no sound.can you help me?
Comment by Guest, posted on Oct 07, 2008
i have same problem,now my sony vaio no sound.pleasa help me....iam sad.
Comment by Guest, posted on Oct 05, 2008
HD error realtek
Comment by Guest, posted on Aug 30, 2008
the same pb
Comment by Guest, posted on Aug 18, 2008
Device manager says everything is now running fine but I have no audio device. I loaded a PCI audio device and it also will not work even though device manager says it is working find. It seems to be related to the Realtek HD driver since this problem appeared after I reloaded those drivers. I finally stumbled on this location after removing audio through the BIOS and then reinstalling it. That was when the driver issue appeared.
Comment by rn3m, posted on Jul 29, 2008
i have the same problem i thought i had a bad setup :S
failure!!
failure!!
failure!!
Comment by kumarv1181, posted on Jul 28, 2008
Intel Desk top board DG31GL using XP Service pack 2
Realtek Audio instalation got failed and i tried with the patch from Realtek for all OS then to i get the same error. Can any one help me out to solve this issue
Thanks in advance
Kumar
Comment by Guest, posted on Jun 26, 2008
hd audio faliure!!
Comment by Ismaljo, posted on May 31, 2008
My problem is the same in others.
Installing HD realtek audio failure..
I cant delte it in device manager.
Pls help me to my problem.the best way to fix this problem
Comment by pjtcopa, posted on Apr 06, 2008
I have the same problem as Amit. Do the instructions given "You will need to find it in Device Manager and remove it before you install the Realtek HD driver" refer to the Realtek device or the Microsoft UAA Bus Driver for High Definition Audio? I, like Amit, am not able to uninstall the Realtek device, comes up with "device may be required to boot the system". Help?
Comment by Guest, posted on Dec 22, 2007
realtek HDA audio driver failure R.1.83
Describe your Operating Systems problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in Baltimore, MD
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
