Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water leak after use from sub-zero water tap
No problem with ice but when using water tap water drips after use. what could be the cause . thanks om arora
  • 999 Answers
Water valve is not closing completely due to mineral buildup or low water pressure.
eric
Posted on Jul 01, 2009
Leaking water dispenser
Bernie,
Your water dispenser is controlled by a solenoid valve that is often in tandem with the ice maker water valve (meaning two valves side by side). Check and make sure the water is dripping from the water outlet tube only, in which case the solenoid valve is leaking. However...sometimes what happens is that the door that isolates the ice shoot (and the inside of the freezer) from the outside can get stuck open. Either blocked, mineral build up, broken etc..and water (melting ice) will drip down and out. This can lead to other problems so be sure the flapper door from the ice dispensor is ALL the way closed.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Sub-Zero 661/F Side by Side Refrigerator
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
Ice maker stopped making ice
If ice maker is not filling with water then fill with tap water and allow to freeze. If ice maker cycles and then does not refill then this points to water control valve. If that happens replace water control valve. Ifice maker does nothing but freeze water to ice then the ice maker will need replaced or parts causing problem fixed. Please call Sub Zero at 1-800-222-7820 and they will refer you to one of their six authorized parts and service centers. Thank You, Sea Breeze
Nov 24, 2011 | Sub-Zero 690 Side by Side Refrigerator
I have a Sub-Zero 550 bottom freezer Ref. It is leaking water all the way back & center beyond the drip pan. I have disabled the ice maker by removing the ice bin and it is still leaking water. I...
There is usually one hose and it could have been moved so its not in the pan any more, you should be able to see it near the pan, from the front with the grill removed, use a coat hanger and hook it back into position, if the pan is over flowing, than that's another problem
Jun 26, 2011 | Sub-Zero Bottom Freezer Refrigerator
Hi. My Sub Zero 632 is dripping water from the bottom corner of the freezer door. Can you tell me what the problem is and how I might fix this? Thank you so much.
It does appear that your side by side refrigerator has an ice maker, so that rules out any extra water from a faulty valve.
I think the seal on your freezer door may be broken/torn.
Usually there is no water (per se) in the freezer, but as things thaw, or as the door is opened it can create condensation that leaks. The freezer will retain cool for a while but eventually things will thaw out and water will leak.
Please check the thermostat for the freezer, and make sure there are no containers leaking in the fridge portion.
Good luck.
Sep 26, 2010 | Sub-Zero 632 / S
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
SUBZERO 695
try this... the water valve in your sub. is located in the upper part. ( close to the condenser fan motor. yes the new one.) tell your TECH to test the water dispenser and by pass the ice maker. the leak is on top part . running all the way dow. good luck.............................LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU.... THANKS
Jul 29, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
103 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
