Won't turn on
SOURCE: Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
SOURCE: Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
SOURCE: Power Requirement for Delphi Roady 2 XM Radio
as long as the voltage of your supply is DC, 6V and has the right POLARIZATION on the power jack. (ie, make sure the center pin matches what the receiver expects... if it's backwards, you risk blowing up your receiver) All of these must match exactly to what the reciever expects.
as for Amp rating, the minimum you must be able to supply is 600 mA. so a 1300mA supply will work just fine!
SOURCE: Delphi Roady xt, cassette adapter problem
I was thinking how can I trick the cassette into keeping the cassette in there because every time I put it in, it just came right back out
This is what I did
Go and find a real cassette and cut out a little piece of the cassette tape and set that aside
Every cassette is different so find a way to attach tape from a real cassette to the cassette part of the cassette adapter
You need to attach the tape so it is flat over the head of the cassette just like in a real cassette, which is the part where the music is transferred, once u get it over the head the cassette deck will think it is a real cassette and it will stay in the deck, the tape doesn't even need to be perfectly flat like in a real cassette tape, it can be all messed up and it will still work but flatter is probably better, so you are just tricking the deck into believing that it is a real cassette, it worked for me and hopefully it will work for you, tell me how it works out
