Question about Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range
I need a jets for my oven converter to butane gas please
  • Whirlpool Master
  • 8,220 Answers
This stove cannot be converted as far as I can see. Looked for a kit.. None to be found. I looked at the regulator . It is not a crank down and flip model. The burner valves have no adjustment orificies.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
    President:
  • 1,136 Answers
Hi, The part # of the kit you need to get is
#8523418.
I hope this helps you.
Please let me know if I can assist you further.
Vic
I want to convert my Mod Nr DGHS90WF gas top from natural gas to bottled gas and I need a handbook please
Hello Robert,
I do not think you need a handbook for that.
Most cooker tops have nozzles that you can replace. They look like the ones in the link.
there are numbers printed on these nozzles.
LPG nozzles have smaller holes in it.
Just find out what size you need, they mostly are wrench 7 mm
Kind regards, Dik
Gas 4 burner cooker jet nozzle LPG propane butane Calor conversion set eBay
Mar 01, 2018 | Kitchen Ranges
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
I have a cannon 10535G gas oven and want to convert it to take bottled gas.Where can I purchase the appropriate converter jets?
Contact the supplier of the gas you intend to use, they can supply the info you need and the jets as well.
Jun 19, 2017 | Cannon Kitchen Ranges
How do you convert from gas to propane ?
You need to change the jets , different gasses have a different size hole in the jet.
The manufacture supplies other jets, if the appliance is designed for both gasses.
LP (propane) jets have a smaller hole than Natural (Methane) Gas.
The pressure of LP gas is higher, to be able to suck in more oxygen.
Jun 23, 2014 | Amana Ovens
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
How to convert a 61" residential rangefrom butane to natural gas?
Ranges come set from the factory for natural gas. To convert it to propane, you should call your propane co and have a qualified serviceman do the work. You can void the warranty if you try to do it yourself and break something or don't convert it correctly. On an expensive range like this, you'll be better off having a professional do it right and keep that warranty intact. It could take 1 1/2 to 2 hours to complete the job. You may need to purchase an LP conversion kit if some of the orifices have to be exchanged, like on a unit with sealed stovetop burners. Write down the make, model # and serial # for reference when you make an appt to have it done. Hope that helps.
May 22, 2010 | Imperial Commercial Cooking Equipment...
Converting fromTown Gas to LPG in gas cylinders
Hi
Thanks for using FixYa. If your range/oven doesn't seem to work at all, check these:
Fuse/circuit breaker
Check to see if power is getting to the range/oven. If even a light won’t turn on then check for a blown fuse or tripped circuit breaker.
Main wiring
Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring
There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Ovens
Hotpoint Gas Range. We changed the jets from Natural to Butane. Now when we try to light a burner it flames up and then dies down to a flame like a pilot. There is no pressure.
Hi, Did you change the setting/cap on the regulator? The orfices in the oven need adjusted as well.
Please let me know if I can assist you further in this matter.
Thanks
Vic
Jul 23, 2009 | Kitchen Ranges
2002 GE XL44 converting from LP to Nat Gas
the jet sizes will have to be changed due to the weights of different gasses
Jan 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool GS465LELS Dual Fuel (Electric and Gas) Kitchen Range Logo
99 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
