1993 Toyota 4Runner Logo
A
Anonymous Posted on Aug 14, 2014
1993 4Runner v6. Engine starts but very sluggish. keep patting throttle to keep running but dies after a couple of min.
Bill Boyd
Level 3:
Top Expert:
  • Toyota Master 53,816 Answers
  • Posted on Aug 15, 2014
Bill Boyd
Toyota Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948652
Points
172802
Run fault codes . check fuel manifold pressure
1 Related Answer
Anonymous
  • Posted on Feb 28, 2011
SOURCE: 1995 C220 Car starts up fine, 2-3 min. later
I own a 95 c220, & it had the same problem, it would just quit running while I was driving it, almost as if it was running out of gas, or stalling. The MB dealer said that there was no code, & that there was nothing they could do. So I found a mechanic in germany online that knew what it was. He said to change the Fuel Relay, if you look in your car manual, under relays & fuses, it should show you where its located. Mine was in the trunk on the right side of the spare tire, and it was Green. It was about 50 dollars from the dealer & they had to order it. The mechanic also told me, to be safe, to also change the Main Engine Relay, which in my car was located on the passenger side, under the hood, close to the windshield. It was white with a clear top. It was about 75 dollars from the dealer, and it showed in my manual where it was located, so I was able to undo it myself. Its simple you just unplug em, & plug in the new ones. And I've never had a problem since, & changed em about 8 years ago, it might be worth looking into. If your Fuel relay is bad and its malfunctioning, it will stop gas from going to the engine, making it quit running. Hope this helps
2009. Turns over and will crank with a boost off. you have to keep patting the gas to keep in running. When you let off the gas it dies. Had no battery trouble before changing the plugs.
Battery and changing spark plugs would be unrelated. First thing make sure the battery terminals are clean and tight. Charge the battery with a charger. You shouldn't need booster cables to crank a vehicle with a good battery.
Clean throttle body and MAF to try and fix the engine dying issue but suspect the battery first..
Derrick Schultz issue - where in the world does he live? Idle issue, no codes, clean Egr 2004 3.0 V6 Accord
there's a website reliable-store
all heavy equipment repair issues servicing, loading, wiring, engine problems everything is covered here its a must try for those who aren't fully equipped with tools or knowledge
99 explorer alarm disables. Motor dies
Anti-theft system can keep vehicle from starting , Alarm is for vehicle content theft , open door without key alarm sounds (horns) ! PATS - passive anti theft system PATS enables and disables the engine from starting ,it will not cause the engine to die ! You have some other kind of problem ! If the vehicle engine doesn't turn over an red light on top of dash flashes fast ,then you have anti-theft system problem !
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood and trunk) and sounds an alarm.
Sputtered out and now it won't stay running; dies when put in gear.
Mass air flow , crank sensor . I wouldn't discount anything . Having a scan tool that can view engine sensor data would be a great help too , testing fuel pressure and flow and back pressure test the exhaust .
058 Engine Hard to Start or No Start Lean Fuel Condition
055 Engine Hard to Start or No Start Scan Data for EGR
057 Engine Hard to Start or No Start Ignition Module Test
007 Catalytic Converter Testing
I got a 1990 ford ranger 2.9 v6 its running very crappy
Fluctuating an high RPMs sounds like a leaking or missing vaccume hose to me, I had simmilar problem found open hole with hose off, replaced it now the RPMs are under 1000 again.
As for the stalling I also am having a simmilar problem, and am finding air in the fuel rail, I suspect the fuel pump is going.
I cant go more than a mile without problems.
2001 S-10 with the 4.3 Vortec engine keeps dieing
Most likely the battery and possibly the alternator are bad.
2answers
Engine wont fire until fuel is poured in throttle body
1993 s-10 should have a 4.3 engine. Your symptoms tell me your throttle body injector is clogged, and only allows so much fuel to pass through it. Therefore, on a idle there is not enough fuel coming through to keep the engine running, or to start it. If you replace the throttle body injector your issue should cease.
I hope this information helps you, and I wish you luck on your repair.
When the temp is cold 40 or below my grand prix won't stay running, its like the carborator is over loading. I can be driving and have to let of the accelarator and it will just die. If I try to warm it...
I'd concentrate my time & money,( $15.00 ) on ECT, "engine coolant temperature sensor" If your V6, is a 3.8, and not a 3.1 then it should be located (threaded in ) right below your throttle body at intake/block area. My guess is the sensor is telling the ECM that engine is already warm, thus only delivering enough fuel for a warmed up engine. Once engine is warm, all's well.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
