Question about Nextar MA791 MP3 Player
My Nextar MA791 MP3 Player stop working.
None of the buttons are working, all I get is a picture of a MTP & MSC.
  • 2,418 Answers
This happened to me with a Mp3 player i had, sweat got into the usb plug and thats that. I sat mine out in the sun to dry, only thing now is the radio side does not work.
Posted on Jul 01, 2009
Enter usb2.0 msd mode - pls help
Usb mode is in settings push center button choose between msc or mtp....
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode.... make sure your usb 2.0 driver is installed....... Connect to the mother board.. MSC is best create a music1 folder and put music in there then there is no switching back and forth to mtp ms....MSC can sync the player and the expansion card
Dec 19, 2010 | SanDisk Sansa e260 MP3 Player
I need all driers about nextar system please
Well you can please follow the below link to get the driver -
http://www.nextar.com/frontend/mp3_players.asp?MODEL=MA791&subpr=&categ=
Good Luck!!
Mar 31, 2010 | Nextar MA791 MP3 Player
My MP3 stopped working. It doesn't need to be
Just to be clear,most players require no special drivers. MSC mode will work out of the box with just about any MP3 player and any OS (W*ndows Linux). MTP mode will work as long as you have WMP 10 or 11 installed. Firstly, I will try to explain MSC mode and MTP mode and what they mean. MSC stands for Mass Storage Class. When your player is in this mode, the computer will see it the same way it would see a Thumb drive or flash drive, as a removable disk. It will assign the first available drive letter to your device, as well as one for the memory card (if it uses one and it is installed). This is probably the more popular of the 2 modes, and is a more "open source" type of standard. Most computers detect the player in this mode without a problem very well and right away.
MTP stands for Media Transfer Protocol. It is a Microsoft standard and is Microsoft's solution to connecting MP3 players and cameras to a w*ndow based Computer. MTP mode must be used in order to transfer ANY Digital Rights Management (DRM) protected content. MP3's downloaded form services like Rhapsody and Napster will only function in this MTP mode.
Most good MP3 players will have both of these modes at the users options.
Although not all do, so it is a good idea to check yours for these settings if you are having connection problems
NOTE: Any songs added to your player in MSC mode will not be available in MTP mode and vise-a-versa. In other words You can't see the files added in the other mode and you can not play them. You know you have some files on your player and can not find them now, you may have to change modes so they are available. Some players in the SanDisk line up use Instead, an "Auto Detect" function that is suppose to Automaticly use MTP mode. If MTP mode does not work for any reason, it should default to MSC mode.
To use MSC or MTP modes go to your players settings.
These settings will vary based on player model and you might have to refer to your users Manual. Check their web site for a download in PDF form. Turn the player on, if it is not already Navigate to the main menu of your player; this is the same menu that gives us options such as Play, Record, Info, etc... Navigate to "Settings" on the main menu of the player. After navigating to "Settings", you should see an option that states "USB" or "USB MODE" From here we can select MSC or MTP modes (could vary based on player model) Highlight the desired mode and select it, at this point it will roll back to the 'Settings' menu Connect the player to your computer and verify it is connecting in the desired mode. It should be noted, when a device is in MSC mode, it will appear as a "Removable disk". When connected in MTP mode, it will show up as an "Audio Device".
Now most players now days can and will use`MS W*ndows Media Player. You can also try to reinstall W*ndows Media Player 10 or 11 Next W*ndows has a update to fix if all else fails try this link. http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en
Feb 13, 2010 | SanDisk Sansa Clip MP3 Player
When i plug my Nextar MA797 20 mp3 player into my computer my computer keeps saying that the usb device has malfunctioned or windows does not recognize it but it worked fine before.How can i fix this or...
Check and refresh the drivers in Windows, for a Portable Device.
1 - Connect your player to the PC
2 - Check under Device Manager
-> 1. Right-click My Computer, and select Manage.
NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode.)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh or reinstall the drivers.
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes. The computer should pick the player and try to reinstall the drivers. *** See again step 1 and 2. See this guys tip for an explanation of MTP and MSC Solve your MP3 Player Connection Problem.
Jan 12, 2010 | Audio Players & Recorders
My computer is saying my mp3 player is not plugged in but ut is. it had no problems before.
Try checking the driver and seeing if it is working right. Here is how you do that:
1. Go to the Windows Desktop, click on the "Start" button, and then click "Run" or "Start Search" if you are using the Windows Vista operating system.
2. Type the following text into the text box:
3. "devmgmt.msc" Click OK.
4. Select your computer when the Device Manager window opens, and then select "Action" from the options at the top of the window.
5. Choose the "Scan for hardware changes" option from the drop down menu that appears.
6. Insert any USB device such as a mouse or flash drive into the USB port in question. Now simply check the USB device to see whether it is working in order to test the port.
Sep 24, 2009 | Nextar MA791 MP3 Player
Change MP3 from USB to MSC mode
Usb mode is in settings push center button choose between msc or mtp.... MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installed
Jun 27, 2009 | SanDisk Sansa e260 MP3 Player
Music on mp3 player not aknowledged by computer
You are right about the Vista. The nextar was designed to work with up to XP. It wasn't designed for Vista at all. You could try getting Vista to treat it as an old OS by selecting the player, (and if Vista works anything like Windows 7) by right clicking on the mouse and select compatibility options. Or finding the option to do the same in Windows, if it doesn't come up in Vista. (Never used Vista so do not know it). Anyway then select the OS of your old computer for the compatibility.
Jul 04, 2017 | Nextar MA791 MP3 Player
I cant put movies on my nextar ma791 . can you help
This isn't a great solution. I used MTVVideoConverter to create an .mtv file. Like you, I couldn't get Windows Media Player to sync the file. However, I put the Nextar into MSC USB mode. Then I found the device corresponding to the Nextar -- which had directories name FMIN.DIR, MICIN.DIR, and MTPMEDIA. I connected to MTPMEDIA and there created a subdirectory called Video (I don't know if the name is important) and copied the .MTV file there. I was careful to "safely remove" the device and I was able to view my video.
There's gotta be a better way.
Dec 08, 2008 | Nextar MA791 MP3 Player
Nextar MA566
I CANT HEAR MY MUSIC ON MY MP3. WHY?
Oct 20, 2008 | Nextar MA791 MP3 Player
Nextar MA791 MP3 Player Logo
138 people viewed this question
Top Nextar Audio Players & Recorders Experts
lolthepcman
ray gallant
Paul Chapman
Paul Chapman
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
