Question about RCA HD52W59 HDTV Projection Television
OUR RCA HDTV HD52W59 LOOKS LIKE IT'S IN 3D
HOW CAN WE MANUALY CONVERGENCE IT OR HOW TO BYPASS THE F1231 BY THE FLYBACK PLEASE HELP DON'T HAVE MUCH MONEY TO FIX AND WOULD LIKE TO FIX OURSELVES THE AUTO CONVERGENCE DOES NOT SHOW UP ON THE SCREEN PLEASE HELP
  • RCA Master
  • 3,459 Answers
You need to replace FL231 and resolder the flyback.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
OUR RCA HDTV HD52W59  LOOKS LIKE IT'S IN 3D - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52W59 HDTV and my kids were watching the other day and all of a sudden the screen went bad. The sound is ok and you can still see the picture however it looks like your watching in 3D...
This is normally an easy fix. I've fixed several of these. When you get the back off of the set, there are 3 small square brown fuses located at the back left corner of the set, if looking at it from the back. They are located next to the right side of the flyback transformer( the large gray or black thing sticking up with the thick red wire coming out of the top). One of those fuses will be open and needs to be replaced, and the pins on the flyback transformer need to be resoldered on the bottom of the board. They will come loose and make the fuse blow. This will fix the problem 95% of the time on this set.
Sep 02, 2010 | RCA HD52W59 HDTV Projection Television
I had 3 pictures in 1 and a bowed 3d screen. I replaced the fuse and re soldered the flyback. The picture looks good now but I still have the 3 in 1 picture?
The problem in in the convergence circuit not the horizontal area. There should be 2 large black ICs inside marked STKxxx. These are the convergence ICs. Try resoldering the pins on these first. Should that not resolve the problem, replace the ICs.
Please keep us posted on your progress.
Dan
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
My rca hd52w59 tv looks like its in 3-d. auto covegnence used to solve the problem most of the time but now it does nothing. pic is constantly looks like 3-d now. the colors r all not right. i get it close...
Hi
Thanks for using FixYa. You’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. You can buy the convergence chips from this link; also if you want you can buy repair kit which comes with complete installation and parts. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | RCA HD52W59 HDTV Projection Television
My RCA HD52W59 HDTV has a convergence problem. It
On your Deflection Board it is the bottom left hand side board has FBT flyback transfomer on it Blowed Fuse FL231 it will be on right hand side of FBT there is 3 of them in a roll small brown rectrangler looking caps but they are fuses ir will be the one in the Middle Call PartStore.com 1-866-925-7278
Dec 31, 2009 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
I have a problem with my 56 inch rca tv while looking at it it looks like your watching a 3D movie can you help?
Ur convergence is dead,Buy a convergence kit use what in that kit.U know how to solder right.Tries these websites for kits.Tv Repair World.com or Ebay.com.
Sep 29, 2009 | RCA HD52W59 HDTV Projection Television
TV RCA HD52W59 NO VIDEO
Sound like convergence supply problem (small fuse near flyback will be open.
Sep 17, 2009 | RCA HD52W59 HDTV Projection Television
Looks 3d
Sounds like your Convergence needs to be adjusted. Go to your Setup Menu and look for Convergence. Choose that and the TV will automatically run it's Convergence program If that doesn't fix the issue then you may have to get the unit serviced
Sep 15, 2009 | RCA HD52W59 HDTV Projection Television
A portion of the left side of my TV looks 3D.
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 there is 3 of them in a roll on right side of FBT/flyback ttransfomer they are small brown rectrangler lookins caps but are FUSES it will be the one in the middle.
Feb 04, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
