You manipulate and configure all camera settings from the menu.
1. For the video settings, scroll through the menu and you'll find what you you are looking for there.
2. To transfer photo to your computer, various options are available.
If your camera came with a CD (driver), install that on your computer, than connect camera to computer, using the usb chord that came with the camera. Switch on camera and you should access the SD card from the My Computer menu.
Another way is to take out the SD card and plug it to the computer by an card reader or from most Note Book computers, a SD card slot built into the sides somewhere. to access the SD Card, you open My Computer and double click on the SD card icon, open the varoius folders in there to find you photos.
SOURCE: Date doesn`t appear on the photo in computer
Download the userguide from the following link and please refer page 74 & 75 http://esupport.sony.com/perl/model-documents.pl?mdl=DSCW50 Good Luck
SOURCE: Need to know how to transfer my photos from my camera to my computer
1. In the absence of the type of your digital camera, I will assume that you are using a USB connection to link your camera and computer.
1. Connect your camera to the computer with USB cord when the camera is off.
2. Switch on your camera
3. If the Camera window doesnot appear automatically go and click the Start button then select the Control Panel
4. In the Control Panel Select the Scanners and Camera icon then you will see your camera displayed on the opened window of Scanners and Cameras
5. Double click the camera icon on the screen and you will immediately see the pictures in your camera being read.
6. A box with the Scanners and Camera Wizard will eppear with "Back", "Next" and "Cancel" click Next and then the pictures in your camera will be displayed with ticks markings
7. If you want to copy all into "My Pictures/..." just select Next and the computer will start copying them.
8. If you do not want to copy all of them then you can unmark those you dont want to copy and click next.
9. Once the copying is through you can rest assured your pictures have been transferred to your computer.
I wish all the best with your new photos on your laptop! Please remember when you are through to switch off the camera to preserve the battery for the next pictures to be taken.
SOURCE: transferring photos to computer
see first urs usb cabel is well fitted in urs pc or not or wid camera.....
if it is fittd well n u r unable to transfer ur photo.....then restsrt urs pc n camera at sm time n see it connected or not....
if all off these methods r useless then transfer urs photoes by using card reader......
but usin carrd reader u can only transfer urs memory card pics...
n also check urs usb slot in pc by attachin urs mobile or ny other device...it works or not....
ask me if it creates more problem.....
thanks...
SOURCE: computer (Windows XP) can't connect to Nikon camera as it used to
hi bauerlina
have you tried using control panel (add/remove programs) to uninstall the nikon software then switch off pc for 5-10 seconds,restart an reinstall nikon soft ware
SOURCE: have a new sony dsc-w120
OK,
Camera has small inbuilt memory that can store few pictures. You can copy these photos in memory stick by inserting memory stick in camera, go to Menu >> Copy >> Yes.
Memory stick stores many photos depends on its size and let memory stick in camera, hook it with computer and transfer photos from memory card.
Thanks.
I'm glad to provide the instructions to transfer images from the Camera to the Computer. Once you connect the Camera to the computer, you will get
the Camera as a removable drive under My Computer. You can open the removable
drive to see the pictures stored in the Camera/Memory Card.
If the Operating System installed in your Computer still
needs a driver, you may use the Memory Card slot on the Computer to transfer
the pictures. Please follow the steps to transfer pictures using Memory Card
Reader in the Computer:
Remove the Memory Card from the Camera.
Insert it in the Memory Card slot in the Computer.
Open the pop up window or find out the removable drive under
My Computer.
Copy the required files to a folder in the Computer.
Note : Most of the Notebooks comes with its own Memory Card
Slot. If it does not, you may get one from the market without much spending.
Thanks for understanding.
Please let me know if you need further assistance.
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
I'm sorry for the difficulties you're
experiencing in transferring images from the Camera to the Computer. Once
you connect the Camera to the computer, you will get the Camera as a removable
drive under My Computer. You can open the removable drive to see the pictures
If the
Operating System installed in your Computer still needs a driver, you may use
the Memory Card slot on the Computer to transfer the pictures. Please follow
the steps to transfer pictures using Memory Card Reader in the Computer:
- Remove the Memory Card from the
Camera.
- Insert it in the Memory Card slot in
the Computer.
- Open the pop up window or find out the
- Copy the required files to a folder in
the Computer.
DCIM
folder contains the images.
Note :
Most of the Notebooks comes with its own Memory Card Slot. If it does not, you
Thanks
for understanding.
Please
