Question about GE Profile Prodigy WPSE4200A
My wnse4200 makes a clunking sound when in the spin cycle and I can stop the drum by hand
  • 1,056 Answers
You may gave a broken pump. or a bad centrifugal switch. turn the washer on its side(unplug it first of cours) underneath the washer you will see a pump attached to the motor. remove the pump by realeasing the two long clips in there and see if a foriegn object is lodge in there. a problem with the centrifugal switch will require replacing the whole motor.This could also be a problem with the drive gears.
Posted on Jul 01, 2009
My Washer/Dryer combo will not spin properly when the cycle is on spin. It all just spins sslloowwllyy. There is a sorta bang sound when it tries to spin :-(
if it is a front loader it could be the bearings, or the bracket that holds the drum could be broken (have been known to corrode and fall apart). open the door and try to move the drum up and down by hand. if you get a clunking movement that's your problem - time for a new machine or expensive repair.
Jul 06, 2016 | Washing Machines
My Duet Washer is making loud noise during spin cycle and has plastic shavings, from front tub rubbing i assume.
Hi, it could be your drum bearings are gone the drum would wobble slightly. A way of checking is , machine unplugged put one hand at bottom front and one hand at top front edge and push up and down if it clunks quite badly then your bearings on the drum shaft are needing renewed. You also have a shock absorber for steading the drum this can also fail. The absorber is very hard to compress so if its easy to compress then it needs re-newed.
Dec 29, 2015 | Washing Machines
My Kenmore stackable washer makes very load noises in the rinse and spin cycle but still works. Anyone have idea why it's making so much noise
Try spinning the drum by hand when empty, the faster the better. Does it sound noisy or is there a grinding sound? It should sound silent or whir as everything turns. If noisy then it may well be the drum bearings. If it clunks then it may be one of the arms that holds the drum in place has broken.
Oct 05, 2015 | Kenmore Washing Machines
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
My washing machine makes a cluck sound at the end
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty.
If that is the case, it is normal and no need to worry about it. However, it you did not have the noise before, then best to get it checked out by a repairer.
Regards
Ash
Nov 07, 2009 | Washing Machines
Washer stopping abruptly at end of spin cycle.
Hi, it sounds like maybe some dust has gotten in the basket drive pads causing it to stick. Has it been happening long? Sometimes it will work its way out. Try turning the tub with your hand clockwise. You can also put a heavy load in the washer (wet) and let it get to a high spin. Then open the lid and see if it starts stopping slower.
If this doesn't clear its self up, you will need to change the basketdrive.
Please let me know if this has helpped.
Thanks
Vic
May 17, 2009 | Kenmore 15864/15862 Top Load Washer
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
243 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
