When the drum goes around, it sounds as if a coin were in it. I can't see anything making the noise. Could something have slipped through a crevice somehow, and will this harm the dryer? Works fine now, just noisy.I've dried three loads with the noise. How do I look for something loose and remove it? This machine is almost two years old.
Re: When the drum gros around, it sounds as if a coin
Hi The noise you are hearing is coming from the baffles inside the drum. These are attatched to the drum with screws from the outside of the drum. Something as gotten inside these baffles and causing the moise.
Remove the front ot top panel (Depending on what model) and take the screws out so the baffle releases.
I hope this helps you. Please let me know if I can assist you further.
Look at the paddles that are mounted to the drum. Most are plastic mounted to a steel drum. Money can find it's way under these and drive you crazy with noise. It will not hurt it, but over time may wear its way through. What happens is during the dry cycle the plastic gets hot, clothes push it to the side a little, loose money slides under gets hung up and stays. try to find which one and get out the old butter knife & try to get er out.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
Probably a coin or something in between the 2 drums being thrown around. You will have to remove it somehow if it is as it will damage the drums. First check for any loose parts in the case that may just be knocking around and then try and see if you can see anything in between the drums by useing a light and looking through the holes in the inner drum. If you see anything that should not be there it will need removing. May be possible to get it out by removing the lower drain hose from the outer drum, the door seal if a front loader or the heating element. Start with the easiest to remove first.
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin,
the main suspect is the drum bearings. Drum bearing failure is common on
washing machines due to water getting into them if the drum bearing
seal fails. To check for drum bearing failure you can take the belt off
and spin the drum by hand. If the drum rumbles when spun then the
bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in
the drum which can be checked for by lifting the drum up and down from
the drum lip behind the door seal. A further symptom of drum bearing
failure is a brown rust patch underneath the washing machine and down
the back of the outer drum, underneath the drum pulley (where the belt
goes) There are usually two small holes at the back of the drum bearings
where water that has got past the drum bearing seal trickles out, and
it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions
inside the water pump. This will cause noise when the washing machine
is emptying the water. Coins or other obstructions can get trapped
between the outer tub and the inner drum. This would produce a lot of
noise on spin as they coins get tossed around inside. Usually, spinning
the drum by hand will not reproduce the noise in the case of coins as
the coins drop to the bottom of the tub when the washing machine isn't
spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This
can also be checked for by taking the belt off and running the motor
alone.
A knocking noise can be a loose tub weight. This would be worse with
heavy loads and would not be present on spin with no washing in. This is
because the knocking noise is caused when the tub (or outer drum)
shakes about on spin. Without washing inside the drum the tub doesn't
move. Another symptom of a loose tub weight is grey concrete dust under
the washing machine.
It's very tempting to ignore noises while the washing machine is still
otherwise working. Some noises can be ignored as they will not develop
into serious faults. Other noises, if left, will cause extensive damage
and can end up costing considerably more than if tackled early or these
days writing the washing machine off. Of course the problem is that you
can't tell which of the categories a noise falls into - so ignore them
at your own risk.
Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
May be loose drum slides can cause a metal scraping noise as the drum rotates. For that you'll need to contact Crosley Service Center.
Good luck and have a nice day
Rating the solution is highly appreciated.
Washing machine is noisyIt's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently. Here's a general guide though -
If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
Coins or other obstructions trapped inside the tub under the drum can make horrendous noises as they get tossed about on spin. They often don't make the noise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and not actually be the cause of the noise at this time
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as the coins get tossed around inside. Often, spinning the drum by hand will not reproduce the noise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
A light scraping or ratchety noise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would normally be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early enough
Sometimes a badly worn drive belt can cause a surprising amount of noise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find no noise.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk. If you have a specific noise you are concerned about, either call an engineer
There are 4 possible sources of noise:
1) Drum support assembly - Open the door and turn the drum by hand. If there is a grinding sound and it feels rough, the roller suppot bearings are suspect.
2) Belt tension assembly - Same test as 1 except if you hear the grinding sound but it feels smooth, check the tensioner roller bearings
3) Fan assembly - this can have bearing failure or get foreign objects in it. Access isusually via the back panel
4) Foreign objects - check for things like coins in the space between the front of the drum and the trim around the door opening
few possibilities here,idle pulleys could be wearing,front drum guides could be wearing,back drum bearing,bit early for these problems though,but sometimes coins get lodged at the drum paddles inside located 120degrees apart which wouldnt be anything to worry about if you can verify this,hope this helps
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
after the load is done look in the unit it and hand spin the drum slowly It sounds like you have a coin or something stuck in the baffles rotate untill you can pin point it..
