Question about Samsung Cell Phones
Instructions for using WEP18 Blue Tooth device
  • 389 Answers
Just press and hold the power button for 5 seconds and u will see a solid blue light, once u see that you need to turn on the bluetooth on ur phone, search for the bluetooth then if it is asking for a pass word just enter 0000.
Posted on Jul 03, 2009
Bluetooth user manual
If you are using Windows 8.1 .please follow the following instructions.
1.go to the PC settings
2. In Accounts goto PC and Devices
3. In pc and Devices click on Blue tooth
4. In blue tooth Switch on the blue tooth button and wait till your device will appear in the list. Click on the device and click on the pair . A code will appear on both device just click yes on the code windows. you will be able to connect the Devices and now it is ready to share the data.
Sep 13, 2013 | HP Pavilion Computers & Internet
Im just 13 so i cant pay anything but i'd appreciat help, I Would Like to pair my Plantronics 220 bluetooth with my Playstation 3 but i baught it used and do not have any instructions on how
ok first you must turn the blue tooth power to on in your games system menu,then you will have to turn your blue tooth device to discovery mode,to do that most blue tooth manufactures use the power button for this feature,by holding down the power button when turning on your headset for 6 to 10 seconds it should put your device into discovery mode,then you can add or search for the blue tooth device from your game system,once it finds it,it will ask you for a pin pairing code .most blue tooth manufactures use a factory 4 digit pin pairing code,they are as follows,try them from first one because i will put them in order from most common to least common,but one of them will work,they are 0000,1234,1111,or 9999, i hope this helps you have fun gaming
Feb 26, 2011 | Radio Communications
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
How to connect a blue tooth with cell phone
HOW TOCONNECT BLUETOOTH
Take care.
Aug 08, 2010 | Cell Phones
I just bought a used blackberry rim and im haveing problems getting it to allow me to bluetooth any pictures or ringtones..please help
For any 2nd hand BlackBerry, you have to format you device and configure newly ,.
for enable blue tooth,
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
sedngi via blue tooth ,
open any picture or ringtone and press the menu button > send using blue tooth”
receiving via blue tooth ,
Screen menu > media> press the menu button ,”Receiving using blue tooth”
Jul 17, 2010 | RIM BlackBerry 7290
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Blue Tooth Connection instructions for a MT Max 4X Headset
Go to http://demos.blackberry.com/8300/na/us/gen/ >
Select "Menu" on the top left > Select "Start Using Your Device" > Select "Connect with Bluetooth Enabled Device"
Hope this helps :)
Oct 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cell Phones Logo
151 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
