Frigidaire Thru-Wall/Window Air Conditioner
Problem for Frigidaire (FAC124) Thru-Wall/Window Air Conditioner
Frost on front grate unit
By vonsplace on Jul 01, 2009
frost on front grate unit, starting frosting up on thel ittle grates
Solution #1
posted on Jul 01, 2009
Not Rated)
TheMobilian
Rank: Guru  Frigidaire Expert
Rating: 89%, 710 votes
Dip the thermostat into a glass of ice water. if the compressor stays on you have a bd control thermostat. Clean your coils. use a foaming coil cleaner that is non rinse for indoor use.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Thru-Wall/Window
Questions and Unsolved Problems for Frigidaire Thru-Wall/Window
Do you recommend Frigidaire (FAC124) Thru-Wall/Window Air Conditioner?
Answer
Answer
I am currently installing my new zw5000 ac. I have followed the instructions and everything is ready... (More)
Answer
I have a window A/C unit. It has worked for years. It worked last month, but it wont turn on now.... (More)
Answer
I have a frigidaire FAA074S7A 6500 BTU window unit from Lowe's. Can window units be mounted in a... (More)
Answer
I have a FRG Model#FAS256R2A only one year old . When it runds it shoots drops of water out of the... (More)
Answer
I got this unit from Amazon. I sent a check for an extended warranty a couple of weeks ago in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire Thru-Wall/Window...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
