Question about Ovens
Oven doesn't heat at setting - Ovens
  • 67 Answers
Sounds like the thermostatic controller is broken. Replace it or get it replaced.
Posted on Jul 02, 2009
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
Gas Oven Doesn't Maintain Heat level after initial warm up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 10, 2011 | Frigidaire Ovens
Only preheats doesn't reach temp
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 09, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
TOP OVEN WORKS OK BUT BOTTOM OVEN DOES NOT HEAT UP
There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
Heating Element is Broken
This is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
Hope this help in solving the problem.....
May 17, 2011 | Ovens
Oven doesn't heat
I'm not sure what properly means.  If the unit is working, you can get a cheap oven thermometer to check the function of the thermostat.  Let the unit come to 350 and check the thermometer.  If it is off by more than about 20 degrees, there is a calibration change method in most oven handbooks.
If the unit is not working at all, this is another issue and needs a different set of diagnostics.
Nov 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
57 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
