Question about Philips Televison & Video
TV GOING ON AND OFF
Turns on for 15-30 minute than it goes off and wont come on for a day an than we try again an it happens again.
  • 261 Answers
It sounds like a ballast issue but your bulb might be going out already so if you haven't replaced the bulb, do that first, if it doesn't solve the issue go with the ballast
Posted on Jul 01, 2009
1993 HONDA SHADOW VLX 600, STARTS RUNS FOR 5 MINUTES AND DIES, I CHECKED EVERYTHING FUEL RELATED,IT'S NOT A FUEL PROBLEM
From your description you can be fairly certain it is an electronic problem.
I had a similar problem once with my Honda CX500. I found the connections to the ignition module had gone green and a good clean up restored normal running.
Mar 18, 2017 | Honda Motorcycles
I have a Soniq 50inch plasma, the picture has turned very red. It has happened in the past, normaly I just turn it off for a few minutes and it goes away, but it has been 2 days now and it hasn't
plama tvs do this often after you have it for a while. there is no salution but to buy a new tv. this happened to my dad's friend and he said you cant fix it you just have to buy a new one. he akso said his next tv wont be a plasma of ant type!
Jun 05, 2012 | Televison & Video
My Acura 3.2 TL year 1999 has recently just started cutting off while driving on the road it goes totally dead and wont start for about 3 minutes or so then will start again . Usually it happens again 2...
Good guess. It's not hard to access the switch on your car. Follow the steps at the link below. Remove the switch and inspect for heat damage. If there is no obvious damage, test the switch with an ohmmeter. Jiggle the switch while testing.
Repair Guides Steering Ignition Switch AutoZone com
Aug 17, 2017 | 1999 Acura TL
Hitachi 55VS69 screen goes black and there is no volume and it will not turn off unless unplugged.
The key here is you have to unplug it---it means the problem is related to the microprocessor which may become confused because of an issue elsewhere in the set---no real easy answer except it may be expensive to locate and fix.
Mar 19, 2012 | Televison & Video
Unit wont turn on??? was charging unit overnight,now wont turn on tried holding all buttons for 15,30 seconds
It sounds like it's time for a new battery. Here is your battery:
http://cgi.ebay.com/550mAh-Battery-SanDisk-Sansa-Fuze-2GB-4GB-8GB-/200582416758
If replacing the battery doesn't get this player up and running, you will need to contact Sandisk for repair or replacement of your player.
  • Website: http://www.sandisk.com/consumer-products/
  • Address: 601 McCarthy Boulevard, Milpitas, CA. 95035
  • Phone: 1-866-726-3475
  • Email: support@sandisk.com
Jul 04, 2011 | SanDisk Sansa Fuze MP3 Player
I was playing the My Life game then the screen just turned off. I thought it was because it needed new batteries so I replaced the batteries. But the game still wouldn't turn on. I tried again the next day...
omg!! thats what happened to me... The batteris you used is a bit cheap... no off. so basically get new batteries put it in the mylife game console. turn it off.. and just wait like 10 minutes and then turn it on it should start working again...
hope this helped xx
Jun 30, 2010 | Playmates My Life Handheld
Atwood 6 gal w/h won't stay lit longer than 12 minutes
After it is stored for the 2 weeks, do you turn water on to it, then bleed out any air through the taps before lighting it? If not try that and see what happens and let me know if any different.
Mar 14, 2010 | RTO Atwood Water Heater - 6 Gal LP
My dell xps wont start properly, yellow blinking light
I have an HP that does close to the same thing. Mine goes into a 'Perm-Sleep' mode that I can't seem to pull it out of. I have to remove the battery, then unplug the power adapter, not in that order. Leaving it in this condition for about a minute so that all the power stored in the RAM goes away. This is the same as holding the power button down for 10 to 15 seconds until it completly turns off, sometimes referred to as a 'Cold Boot.'
Once I have powered it down I have to go into the control panel and select the power settings and make sure that hibernate is not an option. If you close the lid on the laptop and the systems goes into a sleep state, it may be configured to go to hibernate after, say an hour or when the battery gets close to being drained. My computer does not like to come out of hibernate and I have to Cold Boot it, so I just don't let it go into a hibernation in the first place anymore.
May 10, 2009 | Dell XPS 200 PC Desktop
Wont turn off, goes to magic focus
enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Sep 09, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
