Question about Refrigerators
Leaking water from freezer side-by-side GE refrigerator
Leaking water from freezer is puzzling. There is like a small pool of water that collects towards the back of the freezer and leaks down under the drawer where it freezes. From time to time (irregularly) I find water outside the front of the freezer door. Nothing behind freezer and freezer/fridge still cold. Right now I cleaned everything up and shut off ice maker. Not sure where water is coming from.
    President:
  • 1,136 Answers
Hi, It sounds like the defrost drain is plugged. You will need to remove the rear inside panel in the freezer and unp,ug the drain. Once you remove the rear panel, you should see a collestion of ice under the evaporator coil. Locate the drain hole and clear the ice. Flush the drain hole out with hot water to make sure it will drain. You might have to run a wire through the drain or you can flush water through it with a baesting serienge.
I hope this helsp you. Please let me know if I can assist you further.
Vic
Posted on Jul 01, 2009
Kenmore refrigerator
Hi David
In the freezer compartment - under the panel where the water / ice is collecting - towards the back - is a small pan. The pan collects the water when the defroster cycles on to melt ice & frost that collects on the cold coil behind the back wall panel. The pan has an opening with a small tube connected that allows the water to drain out to the larger pan on the floor under the fridge.
If the tube is clogged, the water will not drain and will eventually freeze. Every time the defrost comes on, some of this water will collect under the panel and drip into the fridge compartment if the drain remains frozen.
You will need to clear any obstruction in the drain tube with a short, flexible snake. Access it from the freezer compartment. Remove any built up ice and make sure the pan has not been bent or damaged in such a way that it will no longer allow the water to get to the drain tube. If the tube is clogged due to ice, you will have to thaw it out first. Squirt hot water down the tube to do this quickly - I used a turkey baster and towels in the freezer with excellent results. After the ice has been cleared - use the snake to make sure the tube is open. Replace / repair parts as needed.
After clearing, pour some water down the tube to check for flow. If flowing, empty the drain pan on the floor under the fridge. Next, mix up about 6 to 8 ounces of a 10% bleach + 90% water solution to pour into the drain you cleared. This will kill any biological (mold, etc.) blockage in the tube. Empty the drain pan on the floor under the fridge again - but be extra careful as it has bleach in it.
My fridge did this to me several times before I figured out that ice was blocking my drain. I got a piece of #10 copper wire - long enough to hang from something above (coil, heater, etc.) in the coil compartment down about 4 - 6 inches into the drain tube. Doing this allows the warm air from the heated space during defrost cycles to be conducted down the copper wire into the drain tube - making it it impossible to freeze up. It works perfectly! I recommend a #12 or 10 copper wire, but aluminum works well too. I'd stay away from steel or anything that can corrode - because it will.
Jun 13, 2013 | Refrigerators
Water comes out from under the refrigerator every three or four days. I checked everything under. The water hose is find no leaks. The water tray under is empty. Is not a large amount of water maybe...
I dont know if you have a side by side or the freezer is on top,but thats a fairly common thing and the following is what i already wrote before what to check when it leaks like your experiencing.
SIDE BY SIDE
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
FREEZER ON TOP
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
I hope this will hepl you to fix that leak,
GENE
Aug 17, 2011 | Refrigerators
I have Hotpoint model CTX18BABKRWW Serial#ZT515963. Water is collecting in frige under two drawers. I cannot find a drain or a drain tray. Sounds like a low hum noise. Frig is cold and freezer is...
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
Aug 15, 2011 | Hotpoint Refrigerators
Model ET18NKXDW06. Water dripping from freezer down back of refrigarator. Placed bowl underneath opening to catch water. Should be going down to catch pan right???? Help Nell
Gene
Aug 10, 2011 | Whirlpool Refrigerators
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
Good luck,
Gene
I have a Kenmore Coldspot Model 106.70182000 that is leaking water from the freezer into the refrigerator. Any ideas? Thanks!
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
Good luck
I hope this helps you to stop that leak,
Gene
Aug 08, 2011 | Refrigerators
Freezer leaking
open the freezer panel in back. unclog drain hole where water collects. defrost unit first. put a towel in front of unit for some water
Feb 25, 2010 | Refrigerators
We are getting a small pool of water in the refrigerator, beneath the crispers. It pools toward the front, and we can't tell where it's coming from. Any suggestions?
The water is probably running down the back wall , due to a defrost drain clog . To stop this leak , you will need to remove the food and the ice maker from the freezer ( if equipped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Then re-assemble the freezer section .
Nov 24, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Water collecting in the bottom of freezer.
There's a small drain in the bottom of the freezer compartment. It will clog up from time to time and cause water to pool up, then run wherever it can. So, find that little drain (small hole about the size of a dime or so) and un-clog it. you can do this with hot water and a turkey baster!
Aug 30, 2009 | KitchenAid 25.4 cu. ft. Side-By-Side...
Refrigerators Logo
235 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
