Question about Sony KP-61HS30 TV
Will not power on, red light flashing six times
Kp-61hs30 sony projection tv will not power on, red light flashing six times
  • 26 Answers
The problem is in the power supply most likely. The overvoltage protect circuit is causing you not to be able to turn the tv on. This is common to all tv's. Solution unfortuantely is get another tv unless you know someone who can either work on or replace the internal power supply
Posted on Jul 01, 2009
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
Replaced Convergence chips, same problem
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Mar 01, 2012 | Sony KP-61HS30 TV
I have no picture and the power light flashes green and then red.
I can help you to solve your Sony tv problem.
Is it Sony KP-51HW40 tv or any other model?
How many times red light start blinking after three seconds long pause?
Let me know to proceed, can you check voltages with multimeter in tv circuit board?
Thanks.
Nov 26, 2010 | Sony KP-51HW40 51" Rear Projection...
My Sony kp-61hs30 has no power. no blinking
Check fuses on power/delection board. Besides normal looking fuses there are micro fuses that are small and are yellow or blue in colour
Jan 07, 2010 | Sony KP-61HS30 TV
My sony 51" model KP-51WS510 flahes red 6 times when turning on.
Six flashes of the Red Stand By Light means the +5V line is probably shorted on the A or B board. Could also be an overload. Replacement boards can be ordered here: http://servicemanuals.vstore.ca/
Sep 25, 2009 | Sony KP-51WS510 51" Rear Projection...
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony kdf60xs955
A 6 flash shutdown can indicate power supply problems or an open thermal fuse. To be sure, you should have a technician verify your problem.
Oct 19, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony Projection TV KP-51HW40
thats over current shutdown the +5 line is either overloade or shorted on the A and B boards. You will need to trouble shoot the +5volt line possibly a faulty regulator
Jun 05, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Powers on then right back of light flashes 8 times
i have a sony wide screen projection tv KP-51WS500 Red stand by light on flashs no picture
Mar 10, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-61HS30 TV Logo
690 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
