Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP Laser Jet 2420d
Every page I print something there are lines down the left side of the page along with remnents of the top line all the way down the page.
  • 46 Answers
What your seeing can be caused by several things, but I'd wager you've got either a leaky cartridge or just smudges on your print head. The print unit is in two parts and both will need to be cleaned thoroughly.
First, prep a work area with lots of newspaper and paper towels. You'll need cotton swabs (don't use cotton balls for this) and isopropyl alcohol.
Second, pull the ink cartridges from the unit (they snap out easily) and very gently clean the bottom of the cartridges with swabs soaked in alcohol until they come away clean. Dry the bottom of the cartridges with clean swabs and set aside on paper (careful, they can still leak).
Third, pull the print head assembly from the unit (most have a locking bar that has to be unlatched) and clean the same way as the cartridges. Make sure you inspect for cracks and/or obvious flaws (grooves or lines that shouldn't be there) that can cause problems.
Once everything is dry, put it all back and run the unit through a deep cleaning cycle and head alignment before doing any test prints.
Note: this type of maintenance is good to do on printers with a heavy work load after every sixth cartridge change, or if the unit has been sitting unused for very extended periods of time (more than a couple of months).
Posted on Nov 08, 2007
  • HP Master
  • 1,113 Answers
Drum cartdrige or fuser see for more info t isolate fault refer to
  • Soulvisitor
    Soulvisitor Nov 09, 2007
    Mr jodie's comment is confused because you have your problem listed under officejet 6210 but you have a laserjet 2420. one is ink the other is toner!
    like I have told you and you find so unhelpfull your problem is either the toner/drum cartridge or fuser see link I posted on how to bet is you are using aftermarket cartridge and thats your problem.
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ... > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
When i use the sheet feed on my hp laser jet 2840 to photocopy the printed page has a black line down it what can i do to get rid of this?
Clean the adf scanner glass. This is the thinner strip of glass that is just to the left of the large original glass. Just lift up the top feeder and look to the left side of the glass. Clean this strip of glass with a soft cloth and some glass cleaner. Sometimes whatever is stuck to the glass is hard to get off so keep at it till it goes away. Another tip is if the line is in the middle of the copy then the "spot" to clean is going to be in the center of this strip from front to back. If the line is to the left side of your copy then the spot is going to be towards the front side.
Good Luck and Than You for using Fixya
Nov 14, 2010 | HP LaserJet 2840 All-In-One Printer
Blue and red dots
See if there is something wrong with the pad under the ink carton. There is a little sponge thing that absorbs the ink and transfers it to the paper. The ink could also be the issue. If none of these works, you can just return it for a new one if you still have the receipt
Mar 20, 2010 | Computers & Internet
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
Horizontal lines on printed page
You need a new Toner Cartridge
Feb 01, 2009 | HP LaserJet 1300 Printer
Hp laser jet 2420d printer
check the scan unit or change it
Mar 22, 2008 | HP LaserJet 2420dn Printer
Verticle line down left side of page
Printers tend to have this problem if for some reason dirt gets trapped under the print heads. A standard head cleaning is the best solution, which can be found in the menu.
Mar 18, 2008 | Lexmark X342n All-In-One Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
52 people viewed this question
Ben Johnson
