Question about Samsung SPN4235 42 in. Plasma HDTV
It wont turn on an the light keeps blinking 5 times
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 160 Answers
Is this a digital light television, if it is I had the same problem and found my lamp to be blown and had to be replaced.
Posted on Jul 07, 2009
    President:
  • 1,077 Answers
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you blinking light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 01, 2009
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Outside temperature display on rear view mirror
Here are the instructions to reset flashing airbag light, the instructions are for an Armada but I believe it will work on all Nissan models of this period. It wont hurt to give it a try. If that doesn't work you may have a problem that should be looked at by your local Dealer.
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
www.nissanhelpforums.com
Feb 28, 2009 | 2006 Nissan Altima
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to...
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to keep restarting it. can anyone let us know what the problem may be. Thank you
Jul 17, 2008 | Whirlpool Dishwashers
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
Samsung SPN4235 42 in. Plasma HDTV Logo
239 people viewed this question
Jerry Greenberg
Jerry Greenberg
